Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi wd 52525 dlp shuts down
I replaced the lamp.
The tv powers up fine.
Than after answering the question have you replaced the lamp (yes)
I hit enter.
Then I get a message
"TV wil shut down in a few seconds. Please check to see if the air flow is blocked.
The tv shuts down and the status light blinks(red)
Any suggestions would be helpful
Neal
  • otmar123 Dec 14, 2007
    Tv shuts down and the light will just blink green, unable to reset. Have to pull the electric cord and wait for 5 minutes before it will reset.
    Repair men has replaced the lamp once in June 2007 and again in November 2007. Then had to come back since this did not fix the problem.
    Said he forgot to re-set the system. Two days later the tv did the same thing. Well he be back out today, after calling Mitsubishi.
    I am glad I found this site and you may be able help solve this.
    By the way, we clean the filter every 6 month.
    Thank you for your time.
  • Anonymous Dec 16, 2007
    I have the Same problem.
    Looking below I will look into the "service Bulletin" today.
    Good luck to us all:)
    Genius:
  • 1,030 Answers
Mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Posted on Dec 13, 2007
Hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Apr 30, 2012 | Mitsubishi WD-57733 57" HDTV
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 will not turn on, Flashing Red light.
if that is a dlp tv . not shure just by model. but if it is then they do have a lot of problems with vented filtor capacitors on power supply and other boards. magor work unless you replace chassis. but the very first thing to try is lamp and make shure cooling fans and vents are clean. J.D.W.
Jun 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv stays on for about 3 minutes the shuts off
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Oct 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replaced lamp ,have sound but no pic,shuts down
Thats the code for whats known as lamp abnormality which is actually caused by failed capacitors on the power board. Heres a link to the repair kit that will usually fix that issue. The kit contains the replacement capacitors and also has step by step detailed instructions with photos so you can easialy do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jun 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Just replaced dlp lamp
From what I remember, when you turn on the tv, use the remote and when it asks if you replaced lamp say yes.
Jul 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Problems with Mitsubishi WD-52525
When you replace these laps on these TV's they have an internal clock to countdown the lamp usage. After installing the new lamp the TV asked you if you replaced the lamp and you should answer yes. If not its going to ask again. First thing is go through the motion of replacing the lamp take the lamp out etc. then place it back in the set and turn it back on. Follow the on screen instructions and that should reset the lamp timer.
Jan 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
400 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
