Inch and a half black line down page
...only when trying to copy. incoming faxes are OK. Replaced toner cartridge, wiped glass, etc. No change. An ideas?
Thx
Chris
  • cjblaw Dec 14, 2007
    Sorry bout that...it's a Brother 4750e. I think I figured it out: the light bar has a burned out (actually flickering) section that corresponds to the black line. Looks like I'll need to replace it.
    Thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Not sure what model fax you have, did not specify.
1-check to see if there is a white metal plate opposite the glass.
is there any toner or dark marks on it ? clean or use white out to cover make sure it is dry before using.
2-check the black spongy roller inside the machine
3-it maybe that you have a two unit cartridge, one for toner one for the drum ( which is what it sounds like) pull out and check.
It should be a shiny cylinder, does it have a black ring around it?
4- the last thing to check is the fuser, on its way out of the fax it passes two rollers on on top of the other, it may be a little difficult to see, may have to remove a cover, how do they look?
Posted on Dec 14, 2007
White lines on both faxes and copies
clean the scanner, which is the .5 inch thick piece of glass that the ppr runs over as is is scanned
Nov 19, 2013 | Brother IntelliFax-2820 Laser Fax
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
We have a Brother 4100 Fax Machine. When we send a fax or make a copy, there is a black bar about 2" wide that shows up the length of the page. It does not appear on incoming faxes. I believe it is...
Make sure the **** glass is clean, use a micro fiber cloth to wipe the debris/old toner or white out off the glass. restart the fax machine. If it prints this black line from a copy and it is 2" wide after you have cleaned both the glass and the white reference bar, most likley the scanner itself has failed.
www.brother.ca for further assistance.
Jan 14, 2011 | Brother IntelliFAX 4100 Laser Fax
Incoming faxes have black line running through the centre
If it is just from incoming faxes and not from anything you print/copy then it is the sender's fax machine that is dirty. If everything you do has that line, try cleaning the scanner glass and corona wire.
Jun 09, 2010 | Brother IntelliFax-2920 Fax
Have a Okifax 5400 - changed toner and drum but still getting blank line down side of the page. Any way to fix?
clean the LED array with a soft cloth or tissue or the alcohol wipe that comes with new toner cartridges if you still have it. open the cover to expose the drum on the bottom side of cover is a black bar(LED ARRAY) as wide as the drum but about a half inch thick wipe the bottom side that will face the drum when the cover is closed
May 21, 2010 | Office Equipment & Supplies
Copy and faxes come out with a black line on the left side about an inch from the side.
If your INCOMING faxes have the same black line as your copies then the problem lies in the toner cartridge. A line on OUTGOING faxes and copies would suggest something on the scanner glass. This is a small strip of glass under the cover where your originals are fed into. Another way of testing is to run a report from the operation panel. If a report generated from the machine is ok then it is the scanner glass. If the report has a line then it is in the toner cartridge.
Good Luck
Feb 20, 2010 | Canon FAXPHONE L80 Laser
Copies and faxes come out with 5 inch black area over whole page
Does this same thing happen if you just print a report out of it?
Here's the logic behind this.
If it happens on scanning or copying, but not on printing that's a problem with the scanning section.
If it happens on everything (scanning, printing etc) that's a problem with in the printer controls.
Usually on lasers, if it's printing related, the first thing to do is change the toner.
If the imaging drum (which is part of the toner cartridge) is damaged, it will leave lines down the page.
This is a fairly common problem on refilled toners.
If you have changed the toner, and it still does it, it's a different problem.
Aug 11, 2008 | HP LaserJet 3015 All-In-One Printer
Black lines going across the pages
1 check the toner cartridge see it has toner rings on it
2 open - remove toner check the bottom for a thin glass strip clean
Jun 12, 2008 | Panasonic KX-FL541 Plain Paper Laser Fax
Line down center of page.
Hi Sherrey, I think I can help! If you open the ADF cover where you insert your pages to make a copy. You will see a scanner glass about 1/2 inch wide and runs across the width of the printer. You can take a soft towel and some glass cleaner and clean the glass. There will probably be some white build up that looks like white out on the glass just make sure you clean it very well. I hope this helps!!!!
Dec 04, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
217 people viewed this question
k24674
Marvin
Marvin
