Question about Hampton Bay 36 In. San Marino in Brushed Nickel Fan
Dimmer controls the fan / noisy
I installed the fan and a dimmer switch. It's noisy when the fan is on, but decreases as the light is dimmed. The problem is it also decreases the fan speed. Before I take it down, I thought I'd ask the expert. Ideas?
Mark
  • 99 Answers
Sounds like a wireing problem, You wired the light dimmer into the fan control. thats why the fan slows down when you dim the lights.
good luck-------------tomtaso
Posted on Dec 15, 2007
All power windows and moon roof stopped working on my 08 XL7 Luxury. When any window switch is pressed, all of the switch illumination lights go dim, then gradually get brighter. Took to shop, and they...
. The illumination is controlled by the BCM - body control module .
Interior Lamps Dimming
This group includes lamps which may dim. This group may use a combination of vacuum fluorescent (VF) illumination and incandescent lamps.
• HVAC control module, head assembly
• Rear HVAC control module, head assembly
• Radio
• Rear seat Audio
• The instrument panel cluster (IPC)
• The PRNDL lamp, with the exception of the current gear select position
• Power window switches
• Various switches
When the ignition switch is turned to the ON position, the VF display, radio, turns ON at maximum brightness. When the park lamps are ON, all incandescent back lighting turn ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. When the headlamp switch is placed in the PARK position, the park lamp supply voltage circuit provides an input to the body control module (BCM). The BCM then supplies voltage to the I/P dimmer switch through the I/P dimming lamps control circuit. The setting of the I/P dimmer switch determines the amount of voltage that the I/P dimmer switch supplies to the BCM through the I/P dimming lamps low reference circuit. The BCM then sends a pulse width modulation (PWM) voltage to all the interior lamps. All the VF and incandescent back lighting lamps are provided a specific voltage and are then grounded. When the headlight switch is turned to the park lamp or headlamp position, all incandescent back lighting turn ON at the dimming level indicated by the I/P dimmer switch. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting respond from minimum intensity to maximum brightness in response to the I/P dimmer switch.
Do you know what DTC'S - diagnostic trouble codes are ? Codes set in the BCM
DTC B2610 00: Passenger Compartment Dimming 1 Circuit
DTC B2615 00: Passenger Compartment Dimming 2 Circuit
DTC B2652 00: Passenger Compartment Dimming 3
Circuit/System Description
The instrument panel (I/P) lamp dimmer switch is used to increase and decrease the brightness of the interior backlighting components. The I/P dimmer switch provides a voltage signal that will increase as the brightness of the lights are increased and decrease as the brightness of the lights are decreased. The body control module (BCM) provides a low reference signal and a B+ voltage reference to the I/P dimmer switch. When the I/P dimmer switch is placed in the desired position, the dimmed voltage setting is applied from the I/P dimmer switch through the I/P dimmer switch signal circuit to the BCM. The BCM interprets the signal and applies the dimmed voltage to the I/P lamps supply voltage circuit and the interior backlighting components dim to the requested level. Ground for the I/P dimmer switch is provided at G201.
sunroof fuse 1 20amp / power windows - circuit breaker 25 amp
both of these are located in the instrument panel fuse box .
Mar 10, 2018 | Cars & Trucks
Dashboard lights will go out randomly. It has done it for short periods before but it did it for 200 miles on hwy in dark.
The sensor is usually located on the top of your dashboard. You might see it if you look into your vehicle through your windshield at your dash.
I have seen( one time ) that a gps was bright enough that it caused the dash lights not to come on because the sensor thought it was light outside.
Or you could have gotten a bad sensor.
Oct 23, 2015 | 2010 Chevrolet Equinox
Hunterfan com
If you have a remote then you can't use the dimmer switch on the wall. Put in an on/off switch.
Sep 20, 2013 | Hunter 52" Ceiling Fan With Light And...
WHEN DIMMING IN MINIMUM POSITION THE LIGHTS START BLINKING
Which dimmer do you have. So I can look up the manual.
Are you using a fan dimmer, or light dimmer?
Does the dimmer feel warm to touch? or hot?
What does the dimmer control? Incandescent? Fluorescent?
How many total watts are being dimmed?
Is this a new dimmer or old dimmer that started having a problem?
Add a comment with as much detail as possible for best available answer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 08, 2012 | Lutron DVF-103P-277 Diva Fluorescent...
I have a dimmer switch installed and it wont work with the celing fan
Your question has two switches and 1 dimmer.
The fan switch works.
The light switch works.
The dimmer does not. What is the dimmer connected to?
Dimmers typically will not control fan speed unless they are rated to do that.
Do you have a 3-way switching where two switches control same light, and you installed the dimmer in place of 3-way switch?
Sep 06, 2012 | Westinghouse Contempra Trio 42" Ceiling...
I bought a Hunter fan Model 21778 that uses 2 incandescent candelabra lights. Before installing it I called Hunter support to see if it was okay to use a dimmer switch for these lights (I had already...
They're right, you don't want to control the whole thing with a single incandescent dimmer. First of all, the fan-speed and the lights will all be controlled by the same dimmer setting (dim low, low fan-speed - dim high, high fan-speed) - and the dimmer's not rated to control fans anyway which can result in exactly what they said.
There is a Skylark control, the S2-LFSQ- where half the knob controls the light, the other half controls the fan. The only problem you may (and most likely) have is that in order for that to work, between the electrical box for the dimmer and the fan, there needs to be seaparate wire run for the fan, and a separate wire run for the light so that the dimmer can individual control both.
If that's a problem, I recommend the MA-LFQM-, which includes a module that you install in the ceiling with the fan. The wall switch it comes with speaks to that module, and gives you independent control of the fan and light without having to install new wiring. I have one of those myself, I've installed one in one of my friend's houses, and they work pretty well and then you don't have to worry about what wires you've got in your wall.
Jan 19, 2011 | Lutron Skylark Incanhalogen Dimmer 600w ...
I AM REPLACING A LUTRON DIMMER SWITCH AND HAVE i THINK MADE ALL THE RIGHT CI=CONNECTIONS - COULD A FAULTY GROUNDING BE THE PROBLEM?
As a general rule, grounding will not affect operation of dimmer.
Type of dimmer, type of switch being replaced, type of load, and how you connect wires will affect dimmer.
Here is Lutron dimmer switch page
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
What is the load? Are you wiring dimmer to a ballast? Or fan? Or incandescent lights? Or florescent lights?
Are you replacing a 2-way or 3-way switch?
What color are your dimmer wires?
How many wires were connected to switch?
Can you re-install the switch, and know where each wire went?
Did you replace a light with a fan, and then want the dimmer to slow the fan? Not every dimmer will work with a fan, or florescent lights.
Dimmers cannot dim LED lights.
If I know what type switch you are replacing, and the type of load you want to control, and the specific dimmer you have, I can answer the question.
Oct 12, 2010 | Lutron #D-600PH-DK 600W SP Push Rotating...
My new fan with light fixture is hooked up but it only works through the pull strings not from my wall dimmer. Can someone please tell me why and what do I need to do to have it work from the wall dimmer....
It depends if the fan and lights are ran for separate control. If only one power line is ran from the fan to the switch location than you are out of luck. You should install a switch instead of a dimmer because a fan is not designed to work with a dimmer. A dimmer works by rapidly turning the power on and off faster than our eyes can detect creating a dimming effect for lights. This is not good for your fan. The strength of the fan speed will be limited by the dimming/power output of the light dimmer.
Nov 21, 2009 | Universal Remote Control Hampton Bay...
Dimmer or not?
Are you saying you have a dimmer for the fan light and it does not work, or you do not know if the fan came with a dimmer switch?
Most of these fans have two switches; one is for the fan speed(usually three speed) and the other is for the lights(on -off). Adding a Remote control , which is optional for this unit , will allow for remote speed control(variable or three speed), and light dimmer control. The remote controls can be purchased in your local Home Depot or Lowes store. Hope this helps....
Jul 12, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Light flickers when dimmer switch isn't ''just right''
Compact fluorescent bulbs do not work on dimmers.  You have to use standard incandescent bulbs or not dim the lights.
Mar 20, 2009 | Hampton Bay 52 In. Brushed Nickel Romano...
Hampton Bay 36 In. San Marino in Brushed Nickel Fan Logo
124 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
