Question about Gestetner DSC530 All-In-One Laser Printer
Gestetner DSC530 -- Auto Document Feeder
It does not recognize when paper is put in for scanning or copying. Must put individual sheets on the Exposure Glass and copy 1 page at a time. Is there an easy solution for this?
  • 417 Answers
Normally the cable from the doc feeder has come out. Turn the machine off unplug the cable from the DF to the machine then reinstall it should click turn the machine on then try.
If this doesn't work open the DF cover and check that there are the paper detect fins also when the cover is open then the machine should register a cover open this will tell you if the DF is recognized or not.
Thanks J
Posted on Jan 02, 2008
HP5610 - HORIZONTAL STREAKS ON COPY & SCAN
Yep, only when you use the document feeder? If so, lift the document feeder lid, get a clean lint-free cloth and some glass cleaner. Apply some of the cleaner to the cloth then, clean the small of the two glass areas. That is the only section that reads documents fed through the document feeder! Run a blank sheet of paper through the document feeder first before cleaning and make a copy. Take the copy and, if there is a line (or lines)on the copy, place it on the larger document glass face up.Follow the line to the smaller glass. The dot of debris will usually be there. If you don't see anything wrong, clean the glass anyway. Run another blank sheet through the document feeder. Check that copy. If the lines are gone...Viola! you have solved the problem. It it has not and you've cleaned it more than once, the debris is on the mirrors under the glass and a technician will need to come out, remove the glass and carefully clean the optics/mirrors.
Good Luck.
Aug 28, 2017 | HP Office Equipment & Supplies
I want to copy a legal size document to letter size
when you place the letter on the document feeder manually select the paper tray with letter paper in it and auto enlarge.. you will find the enlarge/reduce button at the right side of the bottom icons on the display..
Nov 10, 2009 | Gestetner DSm660 Copier
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Paper is getting jammed in the document feeder
This problem occur due the DF is not detecting the Orginal size.
Check the Size detection sensor,located when u open the ADF cover u can see, Clean the sensor by blowing.
Aug 12, 2009 | Gestetner - DSm675sp Digital Imaging...
I have a message coming up that I don't know what it means.
ADF = Auto Document Feeder (Usually on top)
RADF = Rear Auto Document Feeder, (On the back)
Something is stuck in one of these, a piece of paper, foam, paperclip, twist tie . . . it could be anything. Follow the squealing sound and check the paper feeder rollers.
Find what is in the way and remove it.
Cheers.
Jun 22, 2009 | Toshiba e-Studio 161 Copier Copier
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
There is a line on the paper when copying on our hp 7680
Is the line apparent when you do a copy off the glass flat or when you copy through the auto sheet feeder?
Lift up the document feeder so you can see the glass. Have a look at the glass can you see and signs of tippex of other stuff on the glass, give the glass a clean and the line should go. If not there may be dust etc inside the optical mechanism.
Mar 23, 2009 | HP Officejet Pro L7680 All-In-One Printer
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Gestetner DSC530 All-In-One Laser Printer Logo
107 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
