Home | Ecoquest | Flair Air Purifier | Light doesn't come on,...
Ecoquest Flair Air Purifier
Problem for Ecoquest Flair Air Purifier
Light doesn't come on, does not purify the air.
By draper25 on Sep 19, 2009
light doesn't come on, does not purify the air.fan runs
Best Solution
posted on Sep 23, 2009
Very Helpful)
pwrman
Rank: Master
Rating: 92%, 8 votes
If the little orange neon light no longer comes on, it is a problem with the high voltage board and transformer. The board sits on top between the plates and the fan.
In my instance, the board had become corroded and shorted the terminals of the voltage regulator located on the board. Also, the ground strap around the ferrite core of the high voltage transformer had become corroded an needed replacement. Also, check the circuit paths from the nearest components to the Voltage Regulator pads. Mine blew one of the circuit traces.
All in all, I replaced the Voltage Regulator, Mouser P/N: 595-UA78L12ACLPE3, Transistor P/N: 512-2N4403BU, Timer IC P/N: 595-NE555P.
The voltage regulator feeds the latter two, as well as the high voltage transformer, I replaced those components as a precautionary measure.
The terminals do get corroded, so check those as well. There are no terminals on the high voltage board other than on top of the proprietary potted black box that feeds the target and neon light. Be careful with the terminal on that box because it breaks easy once corroded. As mine did.
Those components fixed my problem with the high voltage board and no neon light.
Hope this helps, let me know if you have any other questions.
Comments:
Sep 23, 2009
- Also, if the plates ever cracked and arced through, and were inside the unit. It probably blew a fuse. Its located next to the ozone out pins that feed the transformer for the ozone plates. Its the circuit board located underneath the unit. The fuse is black and looks more like an electrolytic capacitor as a reference. Mine is .4 Amps @ 250 V. The top is marked 400mA, 250V. Check with an ohmmeter the pin outs, and if the meter shows "OL" or no ohms passing through, it is faulty. Mouser P/N: 693-0034.6711 (400mA, 250V) Check the ratings on your fuse before ordering that part number, your fuse could be different.
Sep 23, 2009
- An easy way to check the ozone plates is to put a voltmeter on the primary side of the transformer that feeds the ozone plates, the leads from the circuit board underneath to the transformer. If you get no voltage, it popped the fuse. Don't check the secondary side that directly feeds the ozone plates, if it works you will probably fry your voltmeter. Primary only, no voltage, popped fuse.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Ecoquest Flair Air Purifier
Questions and Unsolved Problems for Ecoquest Flair Air Purifier
Do you recommend Ecoquest Flair Air Purifier?
Answer
Answer
just needs cleaned or serviced where do i get this done at
Answer
absolutely nothing happens when i turn it on, it says to check fuse. how do i figure out where the... (More)
Answer
when the unit is on should you see a red light in center i used to but no longer see it.
Answer
Fan doesn't run at all on Flair air purifier, don't see a fuse anywhere that may have popped, no... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Flair Air Purifier:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
