Question about Linksys RV016 Router
Need a Linksys RV016 repaired
RV016 will not boot up - keeps cycling thru boot/diag
  • jbaurys Dec 14, 2007
    Yes, tried that several times. It was up and running with a T1 input and about 12 connected devices. Users complained "net is down". Verified the T1 was OK. Recycled power to router, hit reset button on router, pulled battery and let it sit over night, etc. - no change. Unit keeps cycling in the boot / diag. Will check PS for ripple, but do not see any visual probs with capacitors. Anyone know of common failures on this device?
  • 239 Answers
I know you probally already tried the reset control on the unit. Make sure unit is on when you reset it and hold for ten seconds. If you did that can you give a little more info on exactaly what happend when it quit working for you. Thanks Happy Holidays bear001
Posted on Dec 14, 2007
Ge washer wont shut off during spin have to shut off manually cycles thru all others wjre5550k2ww
Sounds like a timer/control issue issue..( you particular model has a control board instead of timer)..It would be best to call a professional to do proper diag and the repair but if want to risk it and attempt it yourself the part number is WH12X10439...
Good luck
Jul 05, 2017 | GE Washing Machines
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
Why doesn't Cabrio washer wash the clothes?
This model has gone through different control board revisions, could be control board related, service mode would have to be accessed to have machine run thru self-diagnostics. if it does not agitate on self-diag mode, unit needs board
Apr 03, 2013 | Whirlpool WTW6400SW Cabrio Washer
I`m use linksys rv042 router I can try firmware upgrade. after firmware upgrade my router`s DIAG light comes on at that point. If I do a power cycle to it, often times, the DIAG light comes on a stays...
sounds like a bad firmware updgrade,
roll back the firmware by redoing the upgrade with your backup that you made prior to the upgrade.
you made a backup right? they may provide older firmwares on the manfactures website linksys is usually good about this.
Jun 11, 2010 | Linksys RV042 VPN Router
Dell laptop will not boot up?
Turn system on by pressing FN and the power button, this should start the system diagnostics. If hard drive diags pass, then new would be boot to the WIndows CD and Run Repair (Vista) or boot to recovery console (XP) once in recovery console, run the command CHKDSK /R
If running Vista repair, you may need to run the repair tool up to 5 times (Each pass makes a partial repair, it make take more than one to complete all issues)
If Diags fail, replace the hard drive.
Dec 06, 2009 | Dell Inspiron B130 Notebook
Cleaning the boots inside the washer next to the drum
the best is affresh sells for about 6-10 dollars home depot sells it. but the cheaper ones are bleach or white distilled vinegar about 2 cups of either or, dont combine run thru a hot normal cycle no clothes init. also manufacters reccommend leaving door open after last load of day and wiping the inside or dooe and gasket. run thru a clean cycle every other month to keep it clean.affresh now sells a kit with wipies to clean the boot we sell it for 12.99 i dont have part right nowbut can call or email
Sep 16, 2009 | LG WM1814CW Front Load Washer
Keeps logging off
If you cannot log into windows in either the normal or safe mode, your repair options are limited.
You can try the following:
  1. Run diagnostics on the hard drive, see if it fails, if the drive fails diags, replace it.
  2. If the drive passes diags, then try booting to recovery console (Boot to XP CD, R at first prompt. Try running the chkdsk /r command.
  3. If no change, try a repair reinstall of windows.
Jul 31, 2009 | Dell Latitude D600 Notebook
the best thing to do here is have a firmware upgrade which can be downloaded from the Linksys site. Base from experience (we have been using a lot of linksys products and currently we are using an RV016), these lock-up problems are caused by firmware problems and can be solved by firmware upgrade.
Jan 10, 2009 | Linksys RV082 10/100 8-Port VPN Router...
Power and Diag lights blink.
When the diag and power light always blink it only means one thing there's a problem with the router, Try tor eset it by pressing the reset button for 30 seconds then after that tunr off the power for 5 seconds then trun it back on, of the diag and power light are still blinking the router is already bad and needs a replacemenet, If the router is still under warranty have it replace to Linksys this is the number 800-3267114.
Hope that helps.........
Aug 29, 2008 | Linksys Wireless-G WRT54G Router
Router problem: Linksys router (RV016) not working
to reset your router there is a small button at the back of your router press it for a few second then start to configure again open your internet explorer then type the default af add then enter then at the log in box type admin leave the password blank then set up your router by entering your modem ip address, gateway,subnet mask ,dns... to get the ip rigth clik the connction icon at the lower right of your monitor then click status then click support
Mar 18, 2008 | Computers & Internet
Linksys RV016 Router Logo
124 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
