Hi:
I have a used Playstation 2 that does the following when I insert a disc: it either takes a really long time to read the disc, or it won't read the disc at all. Without any rhyme or reason, some discs will read, and other discs (maybe because they're scratched more?) it won't read at all. Any suggestions? I haven't tried anything yet.
Hi, Follow these steps when you are facing "disc wont read" problem Step 1: Remove the disc from the system. Step 2: Use a cloth to clean in small circles around the disc (not in a big circle going around the disc). Use DVD or CD disc cleaner if available. If you use cleaner, use a different dry cloth to clean the disc no more than three minutes after application. Step 3: Verify that there are no disc-destroying marks on the disc. Deep scratches and chips in the middle of the disc can render a disc inoperable.As your Playstation 3 is used more and more, the lens that reads Blue-ray discs can become dirty. This will lead to discs skipping or not being read by the console. If you find this is happening on your Blue-ray discs, either movies or games, you may need to have your console cleaned. Be careful when attempting any sort of cleaning of your console, as improper handling will further damage the Playstation 3. Contact a member of Playstation Support for information on console maintenance. Thank you !!
The 'Disc Read Error' error message, 'Please Insert a Playstation 2 Formatted Disc' error message, or the 'No Data' error message is an indicator by your system that the console is having difficulty reading the game disc. This could be for many reasons; usually this is because the game disc is damaged or unreadable. However, in some situations, this can be a sign of a more serious issue with your Sony PlayStation 2. Try all of the steps listed below to troubleshoot the error:
Check the game disc.
1. If there are any noticeable scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth. Note: Do not rub hard and do not rub in a circular motion as this could further damage the game disc. 2. If there aren’t any noticeable scratches or smudges on the surface of the game disc, try using that game disc in another PlayStation 2.
* If the game disc works in another system, this is an indicator that your PlayStation 2 may be damaged. For information on getting your system repaired or replaced, you will want to contact Sony directly for assistance at 1-800-345-SONY. * If the game disc does not work in another system, this is a good indicator that the disc is damaged or defective. To acquire a replacement game disc, you will want to refer to your manual for warranty information specific to your product.
Some Playstation systems, especially the older models, have trouble reading some newly manufactured Playstation 2 game disks. Sony recommends using their Auto Diagnosis tool (http://www.us.playstation.com/support/ps2/hardwaresystem/default.html) to resolve this issue.
After awhile some games with the purple, black, or blue reading sides and DVDs won't load. The laser in the Playstation 2 either goes bad, or gets shifted out of place. On my Playstation, the laser shifted lower than usual due to moving it. Some people prefer to fix this on their own, while some people pay a professional.
To find out more on fixing the "Disc Read Error" yourself (and VOID THE WARRANTY) go to:
Confirm the disc is inserted
correctly into the PlayStation 2 console (label side should be facing
up when the PlayStation 2 console is in the horizontal position).
Confirm
the disc is clean. To clean a disc, use lint-free cleaning cloths made
specifically for cleaning CD/DVD discs, sold at computer software
stores. When cleaning the disc, we recommend starting from the
innermost circle, and wiping out to the edge in a straight line. We do
not recommend wiping in a circular motion, as it may create more
scratches on the disc. [Note: Other materials, such as a paper towel
or a T-shirt, may also scratch the disc. If there are any scratches,
smudges, or fingerprints on the disc, it may not function properly.]
Try playing different CDs, DVDs, and games on the PlayStation 2 console to see if the problem exists across multiple discs.
To determine if the problem is with the disc itself, try playing the disc on a different PlayStation 2 console (or a PS oneTM or a standalone CD/DVD player, if applicable).
Confirm
that you are not using any game modification devices. Unlicensed
devices such as game modification devices can interfere with the proper
function of the software. We do not recommend the use of any game
modification devices or unlicensed products[1].
Are you using a real game disk or are you using a burned disk? If its burned you need a MOD chip for it. If its real then try to open up the PS2 and try to clean the lens gently with a q-tip. It helped me a couple of times.
Thanks, but how do I DO that? Do I need to open the PS2?
