Our asko 3250 is leaving s film and the soap is not coming out
of the reservoir. It just sticks in there. Thedishes also have a kind
of crust on them.
Check to see that both upper and lower arms are working. You can do this by suddenly opening the diswasher about 6 in and observing if the wand arm on top is revolving. This is done by water from the lower arm being pumped up through a tube mounted in the lower basket that centers over the lower arm and upper arm. Check that the tube is clear. check that water from the lower arm center is being pumped. Check that the hole is clear. if you have hard water, then sometimes the holes get clogged up and the arm will not rotate.(just like a lawn sprinkler) The upper arm rotating is what washes the detergent out of the soap dispenser. To aid in cleaning the spray holes, pour some white vinegar in the bottom of the machine about two cups, and turn the machine on high temp wash. Do not let the mixture drain out untill you have cycled it about five times. When the wash cycle has about finished stop and restart. The acid in the vinegar will help disolve the calcium and hardened soap. After the finish rinse cycle, you can put a little lemon juice in the machine and let it was through, that way the vinegry smell will disapate.
