Question about Philips WACS700 Shelf System
Booting up when system is turned on displays messge booting up, but system will not start any ideas? thanks...
  • 476 Answers
Probably corrupt firmware. You can re-load the backup and restore the system.
Press and hold the SOURCE and STOP buttons whilst plugging into the mains supply.
Continue to hold until recovery option appears.
If this doesn't work, then the backup firmware is corrupt too.
Posted on Mar 10, 2008
  • David Simpson Mar 12, 2008
    Further to my previous post:
    This problem is usually caused by the ribbon cable connection between the front panel and the main unit. Sometimes the problem can be cured by disconnecting both ends of the cable.
    The firmware should still be ok in this case.
    There are multiple processors in the WACS700 unit, and the problem occurs when they can't talk to each other.
    An authorised service agent should be able to sort the problem with a replacement cable.
System restore fails
You can download a recovery CD for this laptop from this WEB site.
http://www.user-guides.co.uk/acer/acerrecovery/acer.asp?keywords=acer+aspire+5250+recovery&recor=1
Feb 18, 2012 | Acer Computers & Internet
Had bluescreen a number of time, but laptop always booted up again. However i now have a black screen and nothing will boot up,even tried the dell recovery disc, but nothing. Any ideas?Thanks
Dell includes a series of tests for a system's hardware into the BIOS called the PSA+ Diagnostics. You can run these tests even if the system lacks any media (hard drive, CD drive, etc.). To launch the PSA+ Diagnostics on this system, perform one of the following actions:
  • Hold down the key while pressing the power button.
  • Turn on the system, press at the initial Dell™ logo screen, and select Diagnostics from the boot menu.
  • Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message Diagnostic boot selected displays. The system then launches the PSA+ Diagnostics.
  • If all tests pass you will need to re-install the operating system software.
Sep 01, 2011 | Dell Inspiron 1501 Notebook
I start my laptop but laptop not take boot xp cd and display messge is media failer chek cable so plz help me fastttt
please restart laptop and press f2 or delete and go to boot options and select boot from cd/dvd and save and exit
Aug 30, 2011 | Toshiba Tecra TE2300 Notebook
Hi, I have Sony VAIO Laptop. The day before
ravi,
if the laptop getting power on and if u can see green light glowing and if you see that hdd keeping on blinking that mean that system is booting but there is no display.
issue is with ribbon cable inside the system u need to replace the cable. if you can do it it is ok other wise take it to service center.
i hope this will resolve the issue.
Jun 11, 2010 | Sony VAIO Notebook
When switching on PC it does not boot up fully
Hi Craig
From what you are descrbing one of the background services is preventing start up from completing
Please try the following
1) Switch on PC
2) Continuoulsy press the F8 key until a start menu is presented, choose safe mode from this menu
3) Once safe mode has loaded up go to Start>Programs>Systems Tools>System Restore
4) From the system restore menu choose 'restore my computer to a earlier time'
5) From the calendar presented choose a date in bold when this fault wasnt happening and then click on next and follow the screen through
6) Let the system restore complete and it will automatically reboot and take you back to the mains windows screen
7) This should hopefully let the hung service be able to run
I hope this has been useful
Mar 10, 2010 | Dell Dimension 2300 PC Desktop
Window 2000: i have an e machine with window 2000 does not start up, what can i do? I check the power is fine and the cable is fine and the pc will go on and than an error messge come on and nothig elso....
That message means that your boot drive, normally drive C: can't be read. The boot sector may be damaged from a virus or the drive itself may have failed.
If you have a recovery disk of your operating system (Win 2000) I would try booting from that after you enter the BIOS setup and change the designated boot drive to the drive letter for your optical drive which should be either D: or E:
Once booted, try to start the installation procedure. I'm pretty sure it will fail if the hard drive is bad.
Oct 25, 2009 | Microsoft Windows 2000 Professional for PC
No display
The new hard drive has to be formatted first, then install the operating system. It cannot find the Master Boot Record. Google Master Boot Record repair on the Microsoft Knowledge Base websiter for instructions to rebuild the MBR..
Mar 02, 2009 | Dell Inspiron 1501 Notebook
Computer starts, attempts to load display, crashes, restarts.
You should do a system restore. It may have happened because of a system update, if your set up to receive them automatically.
Feb 22, 2009 | HP Pavilion dv6605us Notebook
Acer travelmate 2420 laptop
You don't need the original setup cd as long as you have the windows cd you can boot up the pc using that cd and just repair the windows or install it over cause its only a file messed up. Get back to me
Apr 17, 2008 | Acer TravelMate 2300 Notebook
Philips WACS700 Shelf System Logo
743 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
