Gateway laptop vertical dotted lines across the screen
My Gateway laptop is having the following symptoms:
1) BIOS "welcom" screen: Vertical dotted/dashed lines ONLY found in the left side of the screen.
2) Before windows boots: Random characters everywhere glitching and warping characters.
3) Windows XP welcome screen: Dotted vertical lines distributed everywhere.
4) Windows Desktop: Some icons (escpecially white ones) look corrupted; Dotted vertical lines everywhere. Right click menu window leaves a "ghostly shadow" of more distinguished dotted vertical lines.
5) At times there will be a static signal flicker: Dots changes color or randomly disappears. This static happens if there is no physical movements or if it is just idling.
6) Sometimes it fixes itself but it still leaves a matrix of dots. Pressing F5 (Refresh) or resizing windows or taskbar cleans the matrix.
7) Physically smacking the laptop sometimes reproduces symptoms 5 and 6, eg. smacking it fixes the vertical lines.
8) If the laptop is displaying normaly (ie, no dotted lines), opening 3d games or application often reproduces symptoms 4-7, and either disappears at reboot or reproduces all the symptoms.
This problem has happened 3 times already. Laptop has been service by the warranty and they say they replaced the MoBo. I could conclude that this symptoms can be a defective mobo memory or a loose connection. I want to know how to locate such problem in the laptop so i could fix this myself after my warranty expires.
  • Xent007 Nov 03, 2012
    The iGPU is fried. Its dead.
  • Anonymous Mar 23, 2014
    hi i have a samsung laptop when its plugged in the screen is fine but when i remove the charger from the laptop there are like little white dots and lines running across the screen i have changed the screen for a new 1 and also a new screen cable and still have the same problem what else could be casuing this
  • 324 Answers
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Posted on Feb 01, 2008
Dotted lines on laptop screen
This not good, hook a spare monitor to the video output usually on the back, if picture okay! the LCD panel on the laptop will need to be replaced. But if both show the same symptom the video graphics card is bad normally built into the motherboard.
Apr 17, 2012 | Sony VAIO VPCyB13KXS AMD DualCore...
One vertical line on left side of toshiba satelite pro L450 LCD screen
Lines on the screen can be pretty much a hardware (LCD) issue. The first thing to do is to check if this vertical line is present outside of the Operating System so you need to go the BIOS screen of your L450.
How to go to BIOS? : Turn on your computer and start hitting the "del" key repeatedly until you see the BIOS screen.
From there, observe your screen and see if the vertical line is present. If it is, then you need to take your laptop to an authorized service provider (Toshiba) near you and have the LCD of your notebook replaced.
In case the line is not present in BIOS, then a display driver reinstallation using your Toshiba driver disc can resolve this problem. Ultimately, you may need to reinstall the entire Operating system if this still fails to resolve the problem.
All the best, and Thanks for using FixYa.
Feb 19, 2011 | Toshiba Computers & Internet
The problem i am facing is i have vertical lines (blue) on my screen, when the laptop starts there is this unclear dots and dashes all around, the laptop i have is the Fujitsu Siemens Amilo M 1437, if...
Sounds like to two separate problems, the vertical lines, indicate a poorly seated or bad lcd inverter. the other, the dots and dashes sounds like a cpu issue, I would have it looked at.
Apr 05, 2009 | Fujitsu Siemens Computers & Internet
Vertical lines in my laptop screen
Try using an external monitor,every laptop has a blue VGA connector,just connect a monitor there and check is those lines
disappear,if it does,probably you have a problem with the internal connection of your monitor to the motherboard.
Sep 07, 2008 | HP Pavilion dv6000z Notebook
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
Vertical Dotted Lines on my Toshiba Tecra
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to vertical line across the screen . I would like to provide my suggestions on the issue.
I hope that this should work for you and will resolve the issue.
Well, this issue could happen due to below causes:
1. corrupted Display Adapter drivers in PC
2. If the OS gets corrupted.
3. If there is an issue with BIOS
To isolate the issue, I recommend you to try below solutions.
1. Try to work on System Restore if you are using Windows XP or Vista. Sometimes this could resolve the issue.
2.  Then try to load the PC in to BIOS, I mean get into BIOS screen and check if there is any vertical line across the BIOS screen. if you do not see such line while in BIOS, then it confirms that this is an issue with Software related and not  a Hardware related.
3. If  found that this is an issue with Software, then load the pc in normal Mode and then try to uninstall and reinstall the Display Adapter Drivers in your PC. This should resolve the issue. If the issue still persists then go ahead with Reinstall of Operating system. This is only ultimate solution for the issue.
4. If  found issue with Hardware related, I mean if you see a vertical line in BIOS screen, try to Flash the BIOS once. It means Update the BIOS. OR load the Latest BIOS that is available for your PC model.
For your convenience, I made alot of search and found a link for BIOS update.
Link is :
Once if you open the link, please select the correct Product type as : "Portables" and then Family as " Tecra" and then select correct model number of your PC and click Ok.
This opens a new web page, try to locate the updated BIOS driver. If you find there is new updated version of BIOS, then please download and install it. This should resolve the issue.
However, if the issue still persists then it confirms that this is an issue with Hardware Malfunction of PC. Then you need to contact Manufacturer on thes issue further.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at . I'll be glad to help you.
Oct 27, 2007 | Toshiba Tecra M1 PC Laptops
Dotted vertical line on my Toshiba Tecra
Please post in the correct section.
Oct 24, 2007 | Video Game Consoles & Games
Computers & Internet Logo
1,394 people viewed this question
David Payne
David Payne
