Question about Video Game Consoles & Games
Button configuration probz
Bought a Genius maxfire blaze 2 controller but have a problem with the button configuraion. The lay-out of the buttons differs from that shown on screen so to speak. For example button no.1 is where the game (and manual of the hardware) shows button no.4's supposed to be. Only butons that are correct are the directional buttons. There's no place where I can assign the keys to correct the error as the hardwear does the callibration etc. automatically.... Anyway I can fix this?
Hey guys, I have been looking for a driver for my InterAct Magnum 6 joystick. What a run-a-round. I finally figured out that the drivers for the joystick was on Windows 95 and 98, you did not have to download them from the cd, just add the joystick driver through windows hardware wizard. So I went to windows and found tons of drivers for that was supported at that time. here's the site;
http://www.updrivers.com/drivers/Input_Devices/InterAct/9/178/page2.html
Hope you find what you need. They have drivers up to XP. Happy hunting.
Posted on Aug 06, 2010
Try "Control MK". Just google it an get it for free on the net. You can assign almost any function to any button
Posted on Dec 23, 2007
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Genius maxfire g-08xu game controller
yes it can all u have to do is plug it and start playing iv tried it my self
May 28, 2010 | Genius MaxFire G-08XU GamePad
The program button will not reasign any of the buttons
are you using the game to reasign or the actual windows program
Jul 07, 2009 | Pelican XBOX Tomahawk Flight Stick...
Nothing happens when I press a number??
There is no lock button. Calculator may be configured to be in computational mode you are not familiar with: It may be set to do base calculation on base 5, hence the p (pental). Press the reset button on the back, and the default configuraion will be restored.
You should give some time to learn the different mode of calculations.
Hope it helps.
Feb 01, 2009 | Sharp EL-531VB Calculator
How do i find the IP Address on a HP Laserjet 2015N, i have tried pressing the go button for 5 seconds and this does not work
5 seconds may not be quite long enough.. please see extract below from HP web site for the P2015 series.
"On the printer, press and hold the green button for eight seconds, or until the LEDs above the button start to blink. The printer prints out the configuration pages. You will find the IP address on page 2."
Dec 09, 2008 | HP LaserJet P2015dn Printer
Video Game Consoles & Games Logo
516 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
