Question about IBM ThinkPad T23 2647 Notebook
White screen on boot up
My satellite A70 laptop doesn't get past a white screen on start up. Can't access the drive for a reformat or F keys for rom bios.
  • mtnsurfer Dec 13, 2007
    My laptop just did the same thing this afternoon. I did a system update earlier this morning too. I hope it has nothing to do with it.
    When starting my laptop up, it looked like it was starting up in VGA mode but there were strange colorations on the screen the after the windows logo showed up, it turned to a white screen where the log in is supposed to be. I blindly typed in my password and i can hear windows starting up.
    I rebooted in safe mode and selected VGA mode. I can see everything but now it has weird boxed lines everywhere. I really don't know what the problem is. This stinks. I am going to try to backup everything onto an external now.
    Any tips?
  • Anonymous Mar 02, 2008
    rebooted but still same problem
    Problem Solver:
  • 9 Answers
You have some problem with you vga chips the solder joint
you have to get it to technician to heat up the vga chips.
Posted on Dec 22, 2007
How can i go in boot option
Normally when you power on your Toshiba Satellite laptop it attempts to boot the operating system installed on its hard drive.
In some instances you may want to boot the Satellite laptop from a different device, such as an operating system installation CD or a USB drive.
The boot order doesn't have to permanently be set to the hard drive.
It's possible to access the boot order before the operating system loads and change which device is set to boot first.
Turn off the Toshiba Satellite laptop.
Turn it back on immediately and wait for the "press the F2 key to enter Setup" entry to show up on the screen.
Press the "F2" key to access the Toshiba Satellite's BIOS menu.
Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Scroll down to the option labeled "Boot Priority" and tap Enter.
Check through the list of devices and locate the specific device you want to use to Boot your Toshiba laptop, such as "CD-ROM," "USB" or "LAN."
Highlight the name of the device in the list and then tap Enter to make it the top boot priority.
Use the right arrow key again to scroll over to the "Exit" BIOS menu.
Tap the down arrow key to highlight the "Save and Exit" option.
Press Enter to save the new boot order and restart your Toshiba Satellite laptop.
Repeat the procedure when you want to change the boot order back to its original setting.
How to boot your Toshiba PC from CD-ROM, LAN, or diskette
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=403623
Toshiba support
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb42&url=&dialogID=111194172&stateId=1%200%20111190763
Aug 02, 2013 | Toshiba Satellite 2415-S205 Notebook
IBook G4 is stuck at the White Screen with grey apple, and circular loading symbol. It doesn't seem to be able to boot passed the white screen. I bought this used from a friend, it's been working...
Typically this white screen is due to a file system check running. If you boot in to single user mode (boot holding down the S key) you can run a manual file system check by typing in "fsck -f -y" (no quotes). This will run file system check -fix -yes to all
Oct 12, 2012 | Computers & Internet
I cant reformat my toshiba harman kardon?what seems to be the problem?
Try loading it into safe mode, to do this turn off your computer turn it back on and as it starts up hit F8 over and over until you get a black screen with white text that you can scroll through. Then look for something that says "Start windows in safe mode" and select that with the arrow keys to move and the enter button to select. If windows does not enter in safe mode, you may want to post clearer information as to what happens when it loads/doesn't load.
Aug 30, 2012 | Harmon Kardon Toshiba Satellite...
Laptop wont even attempt to load windows??
With this kind of problem, you must put in the Windows software disk and boot. Then select repair Windows from the list. This option will attempt to correct the problem.
If you do not have the disc, boot into the repair / diagnostic mode from the boot screen. See if there is an option to create boot disks.
Jan 04, 2010 | Toshiba Satellite A70 Notebook
My tosiba a70-kl1 starts up with a black screen and error messages stating "PXE-E61: Media tes failure, check cable" and "PXE-M0F: Eiting PXE rom"
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Sep 14, 2009 | Toshiba Satellite A70 Notebook
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba a75 s-206 problems helppppppppppppppp
Sounds like a bad hard drive to me. Take out the hard drive completely from the laptop and boot up with the windows xp cd and it should go past the blinking cursor. At that point you know you'll need another hard drive.
Mar 06, 2009 | Toshiba Satellite A75-S206 Notebook
Reformatting the Toshiba Satellite 5005-S504
you did not specify what operating system you are currently using, anyhow, if you are using winxp, configure the bios setting set the cd rom as your 1st boot device and insert the winxp cd to the cd rom then save and exit the. computer will automatically reboot after exit. a message will appear "press any key to boot from cd" you may press a key. you follow correctly instructions or message from the screen then you will succeed. hoping that this will help you. if you have some queries you may send me thru my e-mail.
Dec 28, 2007 | Toshiba Satellite 5005-S504 Notebook
IBM ThinkPad T23 2647 Notebook Logo
707 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
