Question about RCA BD20TF10 20 in. TV/DVD Combo
Sound with Tv channels but no sound when playing DVD
My tv/dvd combo is acting weird. When I watch regular television the sound works great. When I go to play a DVD, the picture works fine but I get no sound. I plugged in another DVD player to the combo and the sound goes out just fine through the surround sound. Is there some way I can fix the tv so I don't have to plug in a separte dvd surround system to watch and hear dvd's? Thanks for your help!
  • 1 more comment
  • maggie1 Jan 08, 2008
    After playing  DVD's  through my TV with no problems  for over two years,
    I am losing  the sound completely.
    Why?
  • Anonymous Apr 20, 2008
    checked wiring and tried another dvd no sound
  • soniably Aug 09, 2008
    Goodmans Model GLCD15DVD LCD TV combo. Same problem, sound works fine watching tv as soon as I try to watch DVD the sound disappears but the picture is fine. This is a fairly new tv and has been rarely used.
    Does anyone know what the problem is?
    Many thanks
    soniably@gmail.com
  • 279 Answers
SOURCE: DVD PLAYS GREAT, TV AND VCR PLAY IN BLK-WHT W/NO SOUND
You have your DVD connected to your VCR, which is then connected to your TV, right? The problem is Macrovision. It's designed to prevent you from connecting your DVD player to your VCR, so that you can't make duplicates of copyrighted movies. It's a real pain in the neck. Try turning the DVD player off - or better yet, unplugging its power cord (as some DVD players are always in a standby mode, even when turned off). If that fixes the problem, then you need to reconnect your DVD player directly to the TV, not wired through the VCR. If your DVD player isn't wired through the VCR, are you using some kind of wire splitter (one cable branches into two) to connect both the DVD player and VCR? That can also cause this kind of interference, if both have power at the same time. There are video switches you can get to work around that. Here's one such switch (first I found for a decent price with a google search): http://www.pickeasy.com/20070827-video-selector-switch-video-game-p-555.html Hope that helps.
Posted on Aug 30, 2007
  • 9 Answers
SOURCE: RCA 20" TV/DVD Combo - DVD Player says discs not compatible?
Does it work on store bought DVD's?If it does it means it's not compatable with homemade dvd's on pc's or other recorders.If it dose not you have a dirty lens.If a lens cleaning cd doesn't work,the dvd deck has to be replaced,probably exspensive.
Posted on Jan 03, 2009
  • 3 Answers
SOURCE: RCA D52W136D 52 in. TV/DVD Combo dvd does not play
did you try to get a dvd cleaner to clean out your dvd player.
Posted on Feb 14, 2010
SOURCE: no sound playing on rca 26 in tv/dvd combo
Have you tried going into sound settings and seeing if the sound output is set to Tv speakers and not external sound system?
Posted on Dec 02, 2011
  • 47196 Answers
SOURCE: rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Posted on Nov 30, 2013
Can't get surround sound for regular television. DVD sound is great but nothing on the TV channels either regular or HD
Only a digital audio source will produce surround sound.
What's the audio source you're using for TV sound? It shouldn't be the TV, but what IT's watching, like the cable/sat box.
Jun 08, 2010 | Panasonic Home Theater System System
Sound quit while watching TV
Try to do fine tuning with all tv chanels
Sep 28, 2009 | Initial DTV-322 32 in. TV/DVD Combo
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
No sound from built-in DVD player on TV?
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
Nov 22, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
Jan 09, 2007 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
VHS problem, any help?
It sounds to me like you have a problem with the reel sensors not detecting movement of the tape through the VCR. This could also be caused by a defective voltage regulator(s) that powers the sensors. This model was made by symphonic/funai (1-800-242-7158), and it is not likely worth repairing.
Dec 30, 2006 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
RCA BD20TF10 20 in. TV/DVD Combo Logo
976 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
