Panasonic tx-29gf10x image not filling screen
I have a panasonic tx-29gf10x which was working fine, but lately the image hasn't been reaching the bottom of the screen. Its distorted so the bottom part of the image is there, but squashed up.
Any suggestions?
  • Anonymous Sep 23, 2008
    Hi,i have this Panasonic TV tx-29gf10x when i tried to switch on, noting come on the screen but red and green light is on. I did DJ but same problem.
    please need help.
    Atish.
  • ozie_ak Sep 23, 2008
    same problem.
    please need help.
    Atish.
    Problem Solver:
  • 7 Answers
Hi there, I have the same model, and I had a simular problem , except my picture shrunk from each side of the screen into concave arc, if you know what I mean. I thought it might be a faulty horozontal output transistor, so I replaced that but did not fix it.
Eventually the picture quality dropped namely it became out of focus and i couldnt refocus it. Then it stopped all together and I heard a ticking sound, which I found was
coming from the line output transformer. A Tech friend told me it was probably a cracked or burnt out HV Capacitor, so checked them all and ofcourse they were all o.k.
So I have come to the conclusion that the Line Output Transformer is faulty, I hope I
am right as they are not cheap.
I think I have the answer to your problem which is a very simple one:
Adjust the "vertical picture height," and it will bring the picture down and fill the bottom of the screen. To do this adjust the VERTICAL CENTER SWITCH by pushing it forward towards the tube , this switch is on Board
TNP 107985 which is located right next to the AV inputs on the back of the TV, the switch is a round white component with a lever on it, and is located on the top of the board, push it to the max forward position, this should help, but might not fix it enough
depending on how much space u have at the bottom. There are no other vertical height adjustments on this Model so it would have to be a faulty component, like a HV
capacitor or burnt out resistor, or not enough HT drive voltage, which suggests dare I
say it--- Line output Transformer, could be wrong though.
Anyway good luck with your problem, hope what I suggested helps.
Posted on Feb 04, 2008
Picture size on panasonic txl32 tv
Change the aspect ratio on the remote. If this does not fix, change the aspect ratio on your cable or sat box.
Apr 10, 2012 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
I lost driver Panasonic TX-D5L31A-J Touch Screen.
This is the driver that supports the following panasonic monitors.
http://panasonic.jp/support/p3/display/download/ftp/disp.EXE
TX-D1734-J
TX-D14L31-J
TX-D7S35-J
TX-D9S54-J
TX-D5L31F-J
TX-9T55-J
TX-7F22-JN
TX-D2162-J
TX-D7F35-J
TX-D7P35-J
TX-D7S36-J
TX-D1F64MA-J
TX-D5L31TN-J
TX-15MA1
TX-D17P53-J
TX-D7F35F-J
TX-D1F63-J
TX-D5L31A-J
TX-D9L51F-J
TX-M7F22-J
TX-15MB1
Mar 03, 2011 | Computers & Internet
Image totally blurred,
Could be a firmware issue, I suggest you go to the Panasonic website, follow links for support and/or downloads and see if there's a firmware upgrade for your camera.
Failing that, get onto the panasonic tech staff, they may be able to guide you further.
Apr 26, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
TV WONT TURN ON, STAND BY LIGHT FLASHING 3 TIMES CONTINUOUSLY
having problem with sony television the screen when its turn on no images found just found red color on the screen..
Feb 01, 2009 | Panasonic TX-42PT10 42" TV
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
Screen Problems
Has the TV been dropped lately? If so it's possible the coils that guide the electron beam are misaligned. Also many tv's (same for computer monitors) have either manual knobs or firmware controls that allow you to position your screen and adjust height, width, etcetera..
Dec 28, 2006 | RCA T19408 19 in. TV/VCR Combo
Panasonic model TX-29GF10X, went on stand by , and not Switching ON again, what is the majore cause?? or what does the TV need to restart again
Your problem im afraid could be one of several things. Power supply problems,sweep supply,horizontal output transistor,standby power supply. The best thing for you to do , if your not a tech, take the set into a reair depot as these are solid state sets and have no user replaceable parts inside. Good Luck
Aug 28, 2006 | Sony KV-32S26 32" TV
Televison & Video Logo
297 people viewed this question
Top Televison & Video Experts
