Question about Kenmore 98702 Stacked Washer/Dryer
My washer does not work
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
    New Friend:
Its a whirlpool thin twin stackable, didn't see a model number
Posted on Jun 10, 2013
  • 240 Answers
Sounds like you may have a lid switch problem. Without a model number, I really can give you a part number (Kenmore Stacks are made by two companies, Frigidaire and Whirlpool) or a way to get to it. It is right under the lid. Check the top and be sure that the plunger that goes into the hole isnt broke or missing. If you need further help, send me the model number (will start with 417 if its a Frigidaire or 110 if its a Whirlpool) and will try to get you a little more information. The job on either unit isnt that hard, and parts are pretty inexpensive. Let me know. Jim
Posted on Dec 14, 2007
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
My Estate TAWS800JQ washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin. If knob is manually moved from drain cycle to rinse unit will agitate but not drain or...
Possible that the drain pipe is in a height where the water is struggling to lift.
If not id check for a block. I normally find a sock stuck in the drain hose which causes a problem similar to yours
Sep 24, 2017 | Estate TAWS800JQ Top Load Washer
Water will drain durring spin cycle
This is normal on some machines. Run it through a complete cycle it should fill, agitate, drain, some will drain down so low then start spinning as it is draining but should stop draining before it fills or stops. Check if water is coming in at the same time it is draining. If not it may be ok.
Dec 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
My washing machine fails to drain
This could be a bad lid switch. A bad lid switch will allow the washer to fill and agitate but when it comes time to drain and spin it will prevent it from doing this. Check the lid switch.
Jan 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer will not stop!
call a service technician to get a proper diagnosis and quote then decide to fix or junk
Jun 10, 2017 | Kenmore 98702 Stacked Washer/Dryer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
98702 Washer Drain/Spin Dead.
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
396 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
