My Asko 6022 front load washer makes a horrible grinding sound when the water exits the drum during the washing cycle. Any idea what might be wrong? Can I fix this myself or is a repairman in order?
Re: My Asko 6022 front load washer makes a horrible...
Figured this one out on my own. Had to check compartment in bottom left of machine that catches any small items that get loose in the wash (coins, paperclips, etc). We had several items in there that were blocking the impeller from spinning correctly. See manual for instructions on opening this compartment.
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
open the filter and you will find coins or some form of objects that has gone in to the wash by mistake unseen!! empty out the filter and put on wash and it will be fine! if there is water in the drum make sure you put bucket that will fit under filter to catch the water when opening the filter! or if there is a rubber tube you can drain water out from this till empty but this will take time! good luck and dont get wet
If you're hearing gears grind, you're looking gearcase (transmission) issues!!! How old is this unit? A new gearcase...you're looking well over $300!!!
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The
bellows is a rubber sleeve that seals the suspended outer tub to the stationary
cabinet front at the tub opening. Its purpose is to provide a water tight
opening into the tub that can be sealed by the cabinet door, yet allow
flexibility for the oscillation of the tub during the wash and spin cycles. Outer
Tub Assembly
The
outer tub assembly is supported by two suspension springs and stabilized by two
air shock assemblies. A cement counter weight is mounted to the front of the
outer tub by screws. A counterweight is molded into the rear half of the outer
tub. These counterweights prevent excessive oscillation of the entire suspended
assembly during an unbalanced spin cycle. Spin
Basket Assembly
The
spin basket is constructed of stainless steel. The circumference of the basket
is perforated to allow water to flow through it as it revolves. A heavy steel
shaft is pressed into the spin basket support which is then bolted to the
basket. The spin basket assembly is entirely supported by two ball bearings
pressed into the rear of the outer tub. A large drive pulley is mounted to the
free end of the shaft that extends through the rear of the outer tub. There are
three plastic vanes mounted to the spin basket to aid in the washing action
during the wash cycle. The rotation of the spin basket provides both the
washing action during the wash cycle, and water extraction during the spin
cycle.
High pitch "jet engine" noise--A certain
amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in
drum or pump. Stop washer and check drum. If noise continues after washer is
restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To
prevent unnecessary noise and damage to drum, fasten fasteners and turn items
inside out.
Squealing sound or hot rubber odor-- Washer is
overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a
thumping sound. This is usually normal. If sound continues, washer is probably
out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it
rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer
is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for
details.
• Shipping bolts and foam blocks have not been removed
during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts
and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and
rearrange wash load.
Please do rate the solution and revert for further assistance.
Try looking at the solution for loud noise during spin with gray water in drain. This also sounds like the bearings on the shaft supporting the stainless steel drum, in the aft half of the outer drum.
Purchased ASKO Washer WL6511XXLP and Gas Dryer with pedestals, 12/01/09. It threw a drum paddle during 2nd. wash cycle. Damaged several articles of clothing. ASKO replaced the paddle 2/19/09 after a lot of phone calls (lip service from the ASKO 800 #). They claimed the part had to come from Sweden (reason for delay).
Washer threw another drum paddle during 4th. wash cycle. Damaged several more articles of clothing. We have made no claim for the damaged clothing, the retailer has been cooperative.
ASKO has promised to replace the washer after the retailer we purchased the washer from, stronglyencouraged them to do so. We are still without a washer (03/23/09). My wife and I are retired, I am 76. Point being; we do not abuse washing machines and we don't like going to a launder-mat.
I know this is not the venue to address this problem, but am at my wits end.
