Question about HP 1040 Plain Paper Inkjet Fax
Hp 1040 random problems
We are having problems with hp 1040 sending and receiving. We had the phone lines checked. All is clear per phone tech. The problem is random. We can send out today, but having problems with receiving. Checked the manual, no clue what to do next.
  • 3 more comments
  • LNL3164 Dec 13, 2007
    Question: Will the fax machine display a message if the memory is full? What about the toner? Will a low toner message display as well? If not, how would we know to clear the memory? Thanks.
  • LNL3164 Dec 17, 2007
    What should we look for in this case. We can fax some people some of the time, but there are a few we can't fax at all. Could it be the receiving fax line?
  • Theda Jan 30, 2008
    Machine will not receive a fax in auto mode. Only receives if I answer and push the start button. It is very important I don't miss a fax when I am out.
  • Anonymous Mar 27, 2008
    INSTALLED NEW HP 1040 FOLLLOWED MANUEL AND 2 PROBLEMS APPEARED 1 CARTRIDGE NEEDED CLEANED..TOOK OUT AND PUT BACK IN ...CANNOT SEND..DIAL PH # RINGS BUT THAT ALL IT DOES IS JUST RINGS DOES NOT COMPLETE. TALKED WITH ONE OF YOUR TECH'S DID NOT SPEAK VERY GOOD ENGLISH FOR 1 1/2 HR AND GOT NO WHERE... UNDER THE FAX 1ST CONNECTION WAS TO THE HEAD SET -2ND CONNECTIONWAS TO THE WALL CONNECTION THE THE REP SAID 1ST CONNECTION SHOULD BE THE WALL BUT IT DOES NOT FIT.. PER THE MANUEL I HAVE CONNECTED CORRECTLY GAVE MY HOMEPHONE AND CELL PH # I HAVE A COMPUTER - MSG FROM PHONE AND NOW THIS FAX HOOKED UP TO MY ONE HOME PHONE.
  • Anonymous Mar 28, 2008
    COMMENTS TO PROBLEM ON 3-27-08 SOLVED.... I TOOK THE FAX DOWN STAIRS -UNHOOKED ONE OF THE PHONES AND PLUGED IN THE FAX INTO THAT SAME WALL CONNECTION AND NOW THE FAX WORKS OK.... MOST WALL OUTLETS HAVE 2 PHONE HOOK UPS BUT I COULD ONLY USE ONE,.,..
    President:
  • 4,402 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00547&cc=us&lc=en&dlc=en&product=425911&dlc=en&lang=en
Posted on Dec 13, 2007
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
1-the line itself could be bad ( not the jack where you nplug in the wall) the cord itself could have a break in it. try changing the cord cost $1.00 at a dollar store
2-if the memory is full after receiving a lot of faxes, check the memory when it happens
3-if the toner is low it will store it in memory, by you checking the machine turning off and on removing toner etc... you end up resetting it for awhile.
  • CheckitRight
    CheckitRight Dec 14, 2007
    1- depending on the machine it should tell you "memory full"
    you need to check the manual to see if yours does
    2-yes, it should also tell you toner low, but this feature can accidentally be turned off on some models.
    check the setting on your machine.
  • CheckitRight
    CheckitRight Dec 18, 2007
    try plugging a regular phone o that line and call a freind to see if there are any static or anything unusual going on. If not, start with the ones you can't fax at all what do they have in common (area code, zip code, location, ............)
    is your fax sharing a common line with another phone ?
    Random problems are the worst for techs.
    Good luck
Ever since i brought my HP 1040 fax machine i can
it may possible that you have a DSL conn. for internet & phone line.
In DSL conn. we need a DSL filter to be fitted in ur DSL line,so that you can get a analog line for fax/voice calls.
And if you have a VOIP conn. then plz contact HP technical support.
Nov 20, 2009 | HP 1040 Plain Paper Inkjet Fax
Can't receive faxes, I can send faxes and print reports though. messages says "Receiving Error - ask sender to send again". Any ideas?
Have you gotten and old telephone and plug it in where the fax goes and see (hear) if you have any problems with a good dial tone and phone line? Does your phone line go near any high power a/c units big motors, mite think about a ferrite core for the fax/phone line. hav ATT or other carrier check your line. Also check your own line when ATT does it there check is only to the location not inside the house. Does your sure protector protect your phone line, really good sureg protectors protect Power lines fax lines!!! and in some case network lines
Aug 10, 2009 | HP 1040 Plain Paper Inkjet Fax
Machine does not receive faxes
It the funky line DSL?
Fax machines are designed to be on a dedicated ANALOG phone line. Sorry
Oct 16, 2008 | HP 1040 Plain Paper Inkjet Fax
Error code ext. phone to rx
Error : Ext. phone to receive
Here is the manual,
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=02c3572ff6a11ac342ae55fe4e15c1a2&q=hp+1040+fax&e=1
check the conection in the back 1st (In HP fax basics)
Jul 05, 2008 | HP 1040 Plain Paper Inkjet Fax
Not been able to receive fax some time
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00547&cc=us&lc=en&dlc=en&product=425911&dlc=en&lang=en
Oct 31, 2007 | HP 1040 Plain Paper Inkjet Fax
HP 1040 Fax machine
Most likely the telephone line seems to have nise/disturbances and the machine must be getting communication errors.
Please get the phone line checked  from tel company
happy faxing
omnipresent
Oct 16, 2007 | HP 1040 Plain Paper Inkjet Fax
Stretched text on faxes
In my experience, this type of problem is on the sender's end and not the receivers. We have sent faxes before and while they are sending, the paper on our end misfeeds and the received copy on the other end is stretched and unreadable. One way to determine this is to have a few different people from different locations send you faxes. If all the faxes have this problem, then it is a good bet it is a problem on your end. If not, then it is probably a problem with this particular sender's fax machine. I hope this helps.
Jul 27, 2007 | HP 1040 Plain Paper Inkjet Fax
HP 1040 Plain Paper Inkjet Fax Logo
113 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
