Question about BenQ PB8220 DLP projector 2200 ANSI lumens 1024 x 768 Multimedia Projector
BenQ PB8220 DLP projector - lamp button continues to flash after bulb replacement
My projector recently lost bulb operation and shutdown with the bulb light button flashing. I replaced the bulb and the projector tries to power up but when the fans turn on the lamp button starts flashing and will go into shutdown. If anyone has any ideas or suggestions I would appreciate them.
Thanks
Tom
  • 2 more comments
  • DartVeiga Jan 20, 2008
    Hello, I'm having the same problem. Mine is Model Benq PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing. Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem. anyone with similar problem or solution, please contact me at dartveiga@gmail.com
    Thanks!
  • markzabel Aug 15, 2008
    ME too and have returned to Benq FOUR  TIMES AND bought a new bulb.  Now out of warranty.
  • tomhubbard May 13, 2009
    Same issues with our PB8253, intermittent shutoff. Fans working, filters clean, new lamp. Total of 12 units, all doing smae thing.
    Build date of 6/06. any suggestions or do I have new boat anchors?
    tom.hubbardjr@comcast.net
  • Anonymous Mar 18, 2014
    Changed bulb; unit will not start. Flashing orange but bulb will not reignite...
  • 3 Answers
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
Posted on Sep 14, 2009
I have had the same problem about three times over the past two years, I have identified that it depends really much on in which sequence you switch off the projector, esp. if it is connected to another device (e..g amp for home cinema). So first the double press to power off, wait for the fan to cool off (no more sound), click on the on-off button to switch off, then switch off your other device if teh PB8220 is conected to it or a laptop).
Every time I've had the problem (the red lamp flashing after reboot), I've left the projector UNTOUCHED for TWO MONTHS, and it restarted and performed well after that. I know this is a real pain but it worked.
Posted on Mar 28, 2009
  • grahamjat Feb 01, 2011
    I think techvictim may have mistaken DartVeiga's problem Temperature Indicator with the potential problem with the Lamp Indicator.
    Techvictim is certainly correct that the power-down sequence should be followed correctly, otherwise powering back up can be well-neigh impossible.
    However, I do not believe the two problems of a misleading Lamp Indicator and faulty Temperature Indicator are related.
BENQ W1060 projector POWER lamp flashing but not working. What's wrong?
When you replace the lamp you have to reset the hours menu on the lamp. It is found in the menu under settings.
Aug 19, 2014 | BenQ W1060 - Dlp Projector
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
I just replaced the lamp bulb in my projector but when i turn it on it still says lamp approaching shutdown. How do i reset lamp??
You need to reset the lamp timer as follows:
Plug in the power cord and reset the lamp operation time by
holding down the LEFT/RIGHT ARROW KEYS, and the POWER buttons on the control
panel at the same time.
Feb 22, 2011 | Mitsubishi HC1500 DLP Projector
The projector shut off during operation
It is highly unlikely that you will receive any quotes here; this is a repair website, the only sales would be through links on Fixya pages. I'm sure you can get info on price and availability at the BenQ site:
Benq's US homepage
Feb 26, 2009 | BenQ PB8220 Multimedia Projector
Benq PB8220 lamp used for 375 hrs shuts projector automatically
Hi Ash, check your manual as by memory you can do this by a 2-3 button reset via the remote control. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Jan 05, 2009 | BenQ PB8220 DLP projector 2200 ANSI lumens...
We recently replaced the bulb in my projector, but it continued to flash "replace bulb". Today, it was running fine then suddenly shut down. The power light is on, but the projector is not on.
IF you did not reset the lamp counter, the unit will shutdown. To reset, press the left and right arrows along with the power button for at least 3 seconds. That will reset the timer. Update this if that does not resolve the problem.
Dan
Dec 17, 2008 | Mitsubishi ES100U Multimedia Projector
Reset timer
FROM THE PROJECTOR
Press and hold the EXIT Button for 3 seconds to display the total used lamp time.
Then Press the MENU button on the projector during the lamp hour message.
The press the <-- or ---> button to reset lamp hours.
Press EXIT to leave.
Nov 15, 2007 | BenQ PB8220 DLP projector 2200 ANSI lumens...
1,522 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
