Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Dns problem i need the dns numbers to this specific router
  • 239 Answers
You should be able to find the DNS numbers in the routers system controls. If you don't know how to do that I need to know what kind and model of router you have, Just get back to me with the information and I can find out and let you know.. Thanks Happy Holidays bear001
Posted on Dec 14, 2007
Hi Pauline,
Try different using a different DNS address. OpenDNS provides free, fast servers that are used by millions. Here's how to do it with and without a router in your set up:
Mac OS X
  1. Go to System Preferences.
  2. Click on Network.
  3. Select the first connection in your list and click Advanced.
  4. Select the DNS tab and add and to the list of DNS servers.
  5. Click OK
Windows 7
  1. Click the Start Orb, then select Control Panel.
  2. Click on Network and Sharing Center.
  3. Click on your primary connection or Local Area Connection under Active Networks.
  4. Click the Properties button.
    Windows 7 may prompt you for permission to make network setting changes.
  5. Highlight 'Internet Protocol Version 4' and click Properties.
  6. Click the radio button 'Use the following DNS server addresses:' and type and in the Preferred DNS server and Alternate DNS server fields.
  7. Click OK button, then the Close button, then Close again. Finally, close the Network and Sharing Center window.
    At this point, we highly suggest that you flush your DNS resolver cache and web browser caches to ensure that your new configuration settings take effect.
Windows XP
  1. Select Control Panel from the Start menu.
  2. Click Network Connections from the Control Panel choices.
  3. Choose your connection from the Network Connections window.
    If you have more than one, choose your default/current connection.
  4. Click Properties button.
  5. Select Internet Protocol (TCP/IP) and click Properties.
  6. Click the radio button Use the following DNS server addresses and type and in the Preferred DNS server and Alternate DNS server fields.
  7. Click OK
Windows Vista
  2. Click on View network status and tasks.
  3. Click on View status.
  5. Vista may ask for your permission to make changes. If so, click the Continue button.
  6. Select Internet Protocol Version 4 (TCP/IPv4), then click the Properties button.
  7. Click the radio button "Use the following DNS server addresses:" and type in OpenDNS addresses, and, in the Preferred DNS server and Alternate DNS server fields.
  8. Click the OK button, then the Close button, and the Close button again. Close the Network and Sharing Center window.
Generic Router
  1. Open the preferences for your router. Often, the preferences are set in your web browser, via a URL with numbers (example: You may need a password.
    If you're like us, and you set the router password long ago and cannot remember it now, you can often reset the password to the manufacturer default by pressing a button on the router itself.
    Or preferences may be set via specific application for your router, which you installed on your computer when you added the router.
  2. Find the DNS server settings.
    Scan for the letters DNS next to a field which allows two or three sets of numbers, each broken into four groups of one to three numbers.
  3. Put in the OpenDNS server addresses, and, as your DNS server settings and save/apply.
Linksys Router
  1. Visit the router's IP address in a new browser window. is the default Linksys router IP address.
  2. Enter the Network password.
    The "Enter Network Password" window will appear. Skip user name and type the router's password (admin is the default password, if you haven't changed it) and click the OK button.
  3. Type in OpenDNS addresses,,, in Static DNS 1 and Static DNS 2 fields.
  4. Click Save Settings button.
Netgear Router
  1. Type the router's setup URL (, or into a web browser address bar. is the default Netgear router IP address.
  2. Enter the password.
  3. Type in OpenDNS addresses, and, in Primary DNS and Secondary DNS fields.
  4. Click Apply button.
  5. Wait for the settings to be updated.
D-Link Router
  1. Visit the router's IP address ( in a new browser window.
    If you are attempting to configure a D-Link router, take note of your computer's Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be Most D-Link devices use the 192.168.0.X range.
  2. Enter the router password.
    Note: if you have not changed the original settings, the default username is admin and the password is blank (nothing).
  3. Click on the Manual Internet Connection Setup button at the bottom.
  4. Enter the OpenDNS addresses, and, in Primary DNS Server and Secondary DNS Server fields.
  5. Click Save Settings button at the top.
Oct 07, 2014 | Computers & Internet
Can't connect to router interface
Took another look by fixing word wrapping in notepad.
It's missing DNS Servers. Check your NIC settings and make sure you don't have a DNS server manually set to another IP. Plus, you might try resetting the router to default in case there is a DNS modification there.
I'm not sure if this is the cause, but I couldn't hurt. It's part of trouble shooting.
Good Luck!
Oct 02, 2012 | Computers & Internet
Dns servers
DNS servers are the Domain Name Servers which convert the web addresses to the IP addresses. They are specific to your Internet Service Providers or ISP. You need to contact them to find out the primary and secondary DNS servers.
Jul 08, 2009 | Zyxel Prestige 660R Router (P660R)
Wireless modem router
Where are you actually putting your ip and dns numbers? I need to check if your actually
connected to your belkin router, so on your computer we need to launch your command prompt
if your using windows. Can you brief me on what system your using there?
Sep 26, 2008 | Belkin (F5D7231UK4) Wireless Router
the dns setting is the same as your routers ip address
Sep 07, 2008 | Linksys Wireless-G WRT54G Router
I cant get onto internet explorer it says dns error can you help?
Check out your internet connection and its settings, whether it is dial up or broadband oriented.
then you have to know about your ip address of dns server in the network setting places.
you just ping the ip address of dns server following as...
go to start, then run and type "cmd", and it shows the command prompt. type as following format.
ping and press enter key.. this is the sample ip address only. if it gets reply, your dns server is ok. you can use internet. suppose, it wont comes, ask your service provider or support for another or different ip address of dns to check it out.
Jul 21, 2008 | Computers & Internet
Dns problems
The DNS addresses are generally provided by your internet service provider (ISP) for your use. Can you identify your internet service providers web site link or his name and possibly your location in terms of city and state? WIth that information I should be able to access his support site and find the DNS addresses for you.
Dec 13, 2007 | Actiontec GT704WG Wireless Router...
Need some advice
if you jus need the dns ip, then you need to log into your router page and check waht dns ip is assingned in there. if you jus want to chnage the dns , you can use and alternate dns if this issue still persists tell me the problem in more detail i m looged in to yahoo n msn messenger thru samra101......... take care -- samrat
Mar 13, 2007 | Blitzz Technology BWA711 (B3WL000900)...
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
56 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
