Heat circuit runs through thermostats and fuses (most dryers have 4), timer, heating element, and motor. Could be any one of those. Also insure you have 240 volts going to dryer.
I SUSPECT YOU SHOULD CHECK UR MOISTER SENSOR LOCATED IN THE DOOR OF DRYER.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Hi Try pressing normalwash-heatdry-normalwash-heatdry-normalwash-heatdry-normalwash-heat then all the lights come on. Let run for a little bit. then keep pressing the start button. untell the unit shuts off, then try running a cycle.After all the lights come on, stop pushing buttons and wait. The unit will start up after a couple minutes The control board has a memory in it. So if you have cold water running in it one time. It will take longer to warm up. Your memory in the control board says its taking to long to warm up. Shutting down thinking their is something wrong with your heating cycle. .
Thanks for contacting fixya.com
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Okay, the little white thingy you mention is the thermal fuse. If it were to blow, the dryer would not run at all. They usually blow like a fuse and require replacement, however, I have experienced on one occasion where the dryer would shut down in the manner you mention, and it was caused by a thermal fuse that was tripping off. I couldn't explain it, but I replaced it and the dryer worked fine after that. That could very well be a possiblity. Normally, problems like this are caused by the operating thermostat going bad. That the other thingy thats mounted next to the thermal fuse. The link I sent you should have information on how to check them. The heating element should not be considered a problem at this point. It would not cause the dryer to shut down if it were to fail. Your symptom would be a dryer that runs, but does not heat. Let em know if you have further questions.
