While there are some adjustments which can be made in the RSS, doing so would not necessarily solve your problem, as it may create another. These setting would require the radio to be adjusted by a service tech using a service monitor. Your PL problem may simply be a programming issue. Double check the PL setting in the radio, also check to see if it is to be inverted or standard PL. If your radio is Transmitting low to other units, you could also be mixing narrowband and wideband radios. If so, one will talk softly to the other, while the opposing radio will be very loud talking back (among other things). And one other simple thing to check when having Tx issues is the antenna. Be certain you are using the correct antenna, the antenna is free of dry cracks or damage; and the antenna is attached properly.
After checking all the above, if you do not solve the problem, contact your local dealer or service center.
Best regards.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
I'll have a tech look at it, Thanks!
" - tommya931
I have a motorola ht600e on the frequency of 446.??? I find that they are not very sensitive, as my...
(More)
I have a motorola ht600e on the frequency of 446.??? I find that they are not very sensitive, as my ham radio is a lot better on receive I also have one on the ham band this is also very deaf cant hear the repeater even when I can see it have tried tweeking the tuneing inside but no better so are they deaf thank you
stops working intermittantly think its a contact issue but clean contacts works awhile then stops...
(More)
stops working intermittantly think its a contact issue but clean contacts works awhile then stops again
We are looking for a company that can provide our workforce with dependable radio communications on...
(More)
We are looking for a company that can provide our workforce with dependable radio communications on Joint Base Balad, Iraq.
