Question about GE JVM1650 1000 Watts Microwave Oven
Ge sca1001hss01 otc advantum microwave
Hi there, my advantum is working but the light suddenly di dnot work anymore, so I de-mounted the unit, changedthe bulb but still no look, so i cahnged the circuit, still no look, i found this smartboard where the lights cable gets hook up to, once i removed it from its current place and pluged it onto another black box (three off them next to eachother on the smartboard) the light was on, but now it did not go off, no matter if the door was closed or not? where can i get such smartboard, it does not have a serial number on it - as far as i can determine- the smartboards they sell on several online sites, do not look the same. what can you recommend?
  • Anonymous Mar 16, 2009
    to replace the internal light, is it necessary to remove the top cover of this microwave? i do not want to demount it if it is not necessary.
  • 833 Answers
First, order by number. Some illustrations are general. Second, you may find a board rebuilder who will fix yours or exchange it.
I've done this and found that the correct product was sent and worked well.
Posted on Dec 13, 2007
GE Advantium 120 sca1001hss01 stopped working during pre-heating. I had food in oven during pre-heating, no lights at all. power to plug works, could this be a fuse or some other safty switch in the...
It's most likely a failed thermostat.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 12, 2011 | GE Advantium 120 Convection/Microwave Oven
GE SpacemakerXL JVM1443 stays on when door is closed
That's almost certainly a failed primary interlock (upper door switch) or its mount is bad.
See our file on info on door switch diagnosis and replacement.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
NO HEAT IN "OTC" GE MICROWAVE
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("no heat"), as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
Nov 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light bulb in oven went out
Remove the top grill by removing two screws in the top. Pull the top of the grill out towards you as the bottom has pegs on it. About 6 inches from the left is metal cover that you just squeeze with your finger tips to remove. This exposes the bulb.
Mar 28, 2009 | GE Advantium 120 Convection/Microwave Oven
Clicking noise whem door is closed
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Otherwise, see this video for help.
Feb 09, 2009 | GE Advantium 120 Convection/Microwave Oven
Kenmore Elite Advantum 120 Model # 363-63694302 INTERIOR Light not working
I would suggest you look over this excellent tutorial.
If this is not close enough to your oven to help, please reply back.
Oct 05, 2008 | GE Advantium 120 Convection/Microwave Oven
Replace light in overrange GE microwave
Advantum 120 over range microwave - with burned out interior bulb: Remove top fron grill cover -- held byu 2-3 screws on top. Remove sheetmetal plate that lies parallel to top of unit, just to the right of the square plastic porting on the far left of the unit. The sheet metal plating is about 12" wide and 8" deep and is shaped like 2 overlapping rectangles. It is held in place by 1-2 screws. (I don't recall if you needed to remove other plastic grid on right front -- I did, but I was still searching for the bulb). The bulb is located about 5" from the left side and about 2" in from the front, covered by a small sheetmetal box. THe bulb looks like the little halogen bulbs used in low-voltage outdoor lights - but is slightly larger - DO NOT REPLACE WITH THAT KIND OF BULB). Remove the one screw holding the box, unplug the bulb and find a replacement. Can't tell you where to get a bulb -- that's what I'm doing next. Good luck.
Jul 25, 2008 | Microwave Ovens
GE JVM1650 1000 Watts Microwave Oven Logo
233 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
