Question about Toshiba SD-V392 DVD Player/VCR
Vcr recording My SD-V392SU , will not record any channel above 13 even though I have gone in the menu and added all the channels, it still won't accept them. Any help you can give would be appreciated. Marlyn
  • 4,402 Answers
Sounds like you have it set for antenna and not cable.
Posted on Dec 13, 2007
I can no longer receive channels # 4 and # 38 (in Boston), after attempting to reprogram the channels. Why?
In my area, I can't watch anything on CBS, NBC, and some PBS channels even though the transmitters are in Philadelphia and I'm right across the Delaware River in New Jersey. You can try experimenting with antenna orientation or a different antenna or adding a signal amplifier as well as frequent rescanning but results are likely to continue to be disappointing.
Oct 23, 2016 | Samsung Televison & Video
Model SSL2006 will not accept TV (cable) channels above 13.
You must be sure you are in connection with the menu. Read the menu and find [video source] antenna/cable. Be sure you are in "cable" source. And then program your TV for channel search! Try this, and thanks for asking!
Oct 06, 2010 | Sylvania Televison & Video
I have a Samsung HL-S6186W 61" DLP HDTV I could get the hd channels over the air with an antenna before but now I can't get any thru cable without going thru my dvd recorder tuner first which degrades the...
Select TV input, Press Menu, Select Channel, in menu Antenna=Cable (for you), (then perhaps, Auto Program with Cable or Air+Cable), tweak Channel List, turn on LNA if needed, shouldn't be.
Somewhere there may be different modulations, some offset the channel a fraction and are important for channels above 13. I'm basing this on my non-cable Samsung HL-T5687.
BTW, I had an HLS until it gave trouble, paid for an upgrade to LED from bulb when I got HLT. Very pleased, until it fails. -Ken
Jul 15, 2009 | Samsung DLP HL-P5663W 56" TV
In auto program only the first 13 channels are found?
sounds like bad tuner try to program manually and see if it will hold memory
Mar 20, 2009 | Zenith Z32X31D 32" TV
I am trying to get channels above 13. I do not
Try bringing up the menu by holding both volume buttons down at the same time (or use menu button on remote if you have it). Go into CH SET using the channel and volume buttons on the front of set (or use the SET + and - and the ENTER buttons on remote). Go to the TV CATV line and move the arrow to CATV. Let menu time out. This will put tv into cable mode. Hope this helps.
Mar 12, 2009 | Durabrand DU1901 TV
Tobshiba tv stays in one channel.
You might need to go into the menu options and set the input from cable to air or vice a verse. The tv in my kids room is like that if it's set to cable with no input at the cable jack then it only gets one channel even after you try to add channels.
Dec 06, 2008 | Toshiba 36A50 36" TV
Sanyo VCR - further info required
Hi, as stated on other post, VCR cannot be programmed storing sat channels in memory, you can get only a unique sat input channel on VCR.
You can only record from the channel that is currently been received on Sat, you can even use VCR timer, but you cannot store Sat channels into VCR.
all you do is connecting the sat box output to VCR, and VCR will see the SAT box as input, or line 1, or AV1, or external, or something similar, depending on the model.
You cannot program VCR on sat channel, you will need to leave sat box on the channel you want to record, it will be the same on a DVD RW.
Sep 09, 2008 | Televison & Video
I have a Panasonic DMR-EZ47V DVD/VHS Recorder with inbuilt SD Tuner. The problem is that after working well for months the Digital Channels won't display even though the Analogue ones do. It says that...
For an unknown reason the problem was solved by turning off the DVD recorder for a minute or 2 and this reset the the entire recorder. This was done because apart the means of resetting the tuning within the recorder's menu wasn't solving the problem.
Apr 08, 2008 | Panasonic Televison & Video
Receiving tv programs
In the menu theres a channel set up mode. You want to switch from antenna to cable mode, then do an auto search. Then all your cable channels will come in. Your going to need the original remote to go into the correct menu. good Luck
Aug 25, 2006 | Audiovox FPE1078 7.8 in. TV/DVD Combo
Toshiba SD-V392 DVD Player/VCR Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
