a whirring noise is most likley a wheel bearing. The fact that you can make it louder by placing more weight on the that side by turning confirms this. Not sure what you mean by having the front end replaced since this term doesnt apply to this condition.
Maybe the disc reader in the Wii is having problems, this could be natural for the Wii, but if it isn't reading the disc, then try talking to the nintendo company and ask them that there is a loud noise in the Wii when its reading discs, they should know what to do. My Wii does that sometimes, especially Super Smash Brothers Brawl, but it still works though. hope that helps.
This is no doubt your system fan. it may be dusty and now having some trouble doing what it does. compressed air should clean this for you, unless you want to open it and manually clean the fan.
Hope this helps you.
I have the exact same problem when I play Lego Batman on my Wii. Unfortunately, since the Wii version is the same as the Xbox 360 and PlayStation 3 versions, it has lots of data that the Wii console can't handle sometimes, thus making that loud noise and freezing up. You can't fix it, but the best solution would be to:
1) Unplug the Wii, then plug it back in.
2) Start up the game and try that same part again. It should work. If it doesn't, just keep trying.
*Note: When you plug it back in and start the game again, don't do any other levels before the level that keeps freezing up and making that loud noise. I hope this helps.
The first thing to check would be to make sure the power steering reservoir is not running near empty, locate the filler cap for the power steering pump it should be marked and then add the appropriate amount making sure you don't over fill, that may make the sound go away if not we must move on to the next possibility, by the way if the noise gets louder when you turn the steering wheel it is most likely the power steering pump or fluid level is low.
Thats fine. Its probably a little older and if you put any more Wii channels other than the original ones, It takes memory and it needs more computing time. The clicking noise is similar to the whirring noise in a computer. It is reading the disk
Hmmm... well i think its because its thea game or something or that you need to clean the PSP because when you open the UMD drive dust could fly in there or the UMDs might have dust inside and attract more dust but your able to play games right?
