Maxed memory or drivers causing R51e causing BSOD ???
I recently upped the RAM in my r51e to 2048kb of Crucial RAM. My R51e has been acting fine up until now. After getting the ram installed, I began seeing the BSOD. Sometimes before login, sometimes after login. Usually don't get the BSOD when booting in safe mode.
I ran Microsoft's memory diagnostics and my RAM failed the LRAND and Stride6 tests -- with the cache on. With the cache off, it passed the test.
I've updated all of my drivers but I'm still suspicious that it could be an issue w/ the built-in ATI video chip.
Can I turn my processor's cache off? Is that the issue? I swapped out both sticks of RAM and they run fine by themselves. But, when I run them together and max out my RAM, I get the BSOD.
Also, when I have 1gb and 512kb of RAM only 1gb is available when I boot up.
I just did the same thing (upgraded the memory to 1.87 gig) and I am getting the same problem. Did you ever get it figured out? I updated the bois and system controller, and still get the blue screen of death.I just did the same thing (upgraded the memory to 1.87 gig) and I am getting the same problem. Did you ever get it figured out? I updated the bois and system controller, and still get the blue screen of death.
I purchased 2 x 1GbRAM for a IBM Thinkpad R51E. Each module (Crucial) installs and runs MemTest with 0 errors but when I install them both together MemTest fails immediately. Virtual Page File has been updated
You can't post conmments that contain an email address.
Re: maxed memory or drivers causing R51e causing BSOD ???
You're mixing 2 different things. the cache is very small, 512KB , 1MB, 2MB 4MB(at the newest CPUs) and it comes with your CPU, when you change the CPU, you change the cache, you cannot work without the cache, its impossible.
the ram, however, is upgradable. and its typical sizes are 512MB, 1GB... etc.
have you updated the BIOS?
are the memory sticks fit for your computer (some times, the fact the memory sticks have different speeds can cause problems?
you are not suppose to see the cache (512kb) of your boot up
http://support.lenovo.com/en_US/downloads/default.page? (Copy and paste to browser)
b>
Please, we need to know how we are doing! Please rateour help to you and leave us a comment so we could go on helping people likeyou that need our assistance and expertise! Thankyou for using FIXYA!Bestregards, Junior
you might have put in the
wrong password or user id check to make sure you have put these in correctly
first make sure the caps lock is on/off what ever applies to your user and
password id that you provided to your ISP also you might have to open up
your network connections click start control panel network connections this may
vary depending on your operating system look for local area connection if you
see a red x or a yellow exclamation or question mark you will need to update or
install the driver or it could be firewalled make sure your
modem/routers settings are correct ie:password user name,firewall settings to
allow your internet to connect also test the lead/s whether usb or ethernet you
might check your modem first to make sure that you are getting a connection click start control panel
administrive tools computer management device manager scroll downnetwork adapters + expand Ethernet driver
you might see a yellow question mark? This means you need to update the driver
right click you will have options to update driver disable uninstall or select
properties general you will have the options to troubleshoot or to update
driver rollback or uninstall a yellow? question mark
means you need to install/update driver right click to install driver last
resort ring
your ISP internet sevice provider get them to check your modem for internet
access online hope
this helps
if you are using windows xp, then follow these steps: 1) right click "my computer" icon, select "advanced" tab, click settings button towards the right of "start up and recovery" and click "edit" tab a notepad window appears with some text in it which reads something like this :
[boot loader] timeout=0 default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /FASTDETECT
modify that text to look like this: [boot loader] timeout=0 default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /FASTDETECT /3GB /userva=2800 /NoExecute=Op
Warning : only the "/3GB /userva=2800 /NoExecute=Op" has to be added extra else you will mess up
2) save the notepad and insert max ram, and check, if any BSOD's if the problem persists, then it is hardware related.. Most probably one of your ram stick may be the problem child(which may be either incompatible with your motherboard or defective)
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state.
RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
hello try to boot in safe mode.(press F8 after bios bootup)
if that doesent work run chkdsk.(boot from windows cd and choose R(repair mode) go to the console and write chkdsk /R let that run and try to restart when its done.
On the bottom of the laptop there are one or two panels, remove the screw securing the panel. The RAM module are behind one of the panels. If the memory module does not fit in the memory slot, then you have the wrong type and you need to purchase the correct memory type.
Your friendly computer shop can advise you on the correct type and speed of the memory module your laptop requires.
I purchased 2 x 1Gb RAM for a IBM Thinkpad R51E. Each module (Crucial) installs and runs MemTest with 0 errors but when I install them both together MemTest fails immediately. Virtual Page File has been updated
