Question about Nikonos V 35mm Point and Shoot Camera
Light meter does not turn on
When there is no film in the camera I can get the meter to work.  After it is loaded, the meter will not turn on.
the batteries are good.
  • 667 Answers
The frame counter must be at '1' for the meter to work on this camera
Posted on Dec 23, 2007
Light meter
The light meter in an SX-70 is not adjustable. If the film is overexposed either the film is bad or something is blocking the light meter eye. Look for dust or debris on the eye surface and clean.
Feb 09, 2014 | Polaroid SX-70 Film Camera
My Mamiya C330 Pro only gives me 4 photos per roll
A few things to consider:
-Loading: Make sure you are not over loading the film before you start to shoot. I have sometimes turned the film advance too many times and end up cutting down on the amount of usable film.
-Are you loading the film in a dark area and careful to close up the back just after it has started to load to avoid exposing it?
-Shooting: Are you metering properly when shooting? Obviously underexposed images won't develop. You should consider a hand held meter.
-Shooting: Are you advancing the film more than it needs to be after you take your shot? Watch the film counter and feel for that click as it hits the next frame. I have advanced past the next shot many times by accident.
Hope that helps, Matt
Apr 05, 2011 | Mamiya C330 F Professional TLR Film Camera
How do i know when my battery is dead. Every time my pictures are developed, they come out black. how do i use the exposure meter?
The K1000 is all mechanical, the battery only powers the light meter. So even if the battery is dead, then you should still be getting images even if very over or under-exposed.
If the images are totally black on the negatives, then your shutter is stuck open and massively over-exposing your images. If the images are black on the prints, then the negatives have been unexposed and will be totally clear. The latter problem means that the film has not been exposed at all and is either due to incorrect film loading, faulty film winding, or a shutter which fails to open.
To eliminate the possibility of a shutter fault, hold the camera up to the light with the camera back open and fire the shutter at each setting. You should see light as the shutter opens and from 1s to 1/30s should be able to see and hear the difference at each speed.
To check film loading and advancing correctly, load a film and wind film on (remember this camera needs the film leader to be manually engaged onto the take-up spool). Use the rewind crank (do not press the rewind button) to take up the loose film and take a few shots. You should see the rewind crank turn each time you advance the film if it is correctly loaded and advancing. If not, open the camera back and visually inspect the film. It should be securely engaged into the take up spool. With the back still open, advance the film and take a few shots: the take-up spool should be advancing and the sprocket wheel (just before the spool, it's the wheel which engages the holes at the edge of the film) should also be turning. If it isn't, then the film rewind mechanism is faulty and the camera is behaving as if the rewind button has been pressed. It's usually easy to remove the bottom of the camera to check that the button isn't sticking.
If all checks so far are OK then check the film pressure plate on the inside of the film door. It should be able to give a little when pressure is applied and holds the film firmly in contact with the advance sprocket, if not then one of the seating pins on the flat metal spring may have become dislodged and it's usually easy to reseat it. Clean the plate after touching it as it must be grease-free and spotless.
If you try all this and still have a problem then please add a follow up comment and I'll try to respond asap, but bear in mind that as I'm in the UK I may be in a different time zone to you.
If I've fixed your problem, then please take a moment to rate my answer.
Aug 19, 2010 | Pentax K1000 35mm SLR Camera
When film loaded it is not rolling on properly
film not advancing? film not rewinding? film transport motor dead/ needs replaced.
Rewinding but counter not resetting and light meter dead? Prolly bad connector or ic inside camera = repair shop.
Oct 16, 2009 | Photography
Light meter not working
Make sure the battery lid is securely screwed on, The meter wont work before the '1' frame. i just found out last week about this. make several clicks till the '1' mark appears, now check the meter if its working. [A] - aperture prio
Jun 09, 2009 | Nikon F3 35mm Film Camera
Film = no light meter
jackson rook,
the speed of the film may be to high if your camera has dx coding contacts in the film chamber. otherwise---- film in camera or not it has no effect on meter operation. move the advance lever to the right slightly and push down on the shutter release button slightly to turn meter on.
Sep 10, 2008 | Vivitar V4000 50MM 35mm SLR Camera
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Apr 28, 2008 | Vivitar V3800N 35mm SLR Camera
Mamiya RZ67 Camera Older model.
Problem solved- The camera does not operate correctly unless the battery is in good condition, in place, and all the contacts are clean. In the RZ76 as opposed to the old RB models the components "talk" to each other: via electronic circuits. The back "tells" the camera bod if the dark slide ins in or out and whether the film is loaded or at the end of the roll. If the batter voltage is too low or the contacts are no clean and making full contact the body has no way of knowing the condition of the film backs and the interlocking mechanisms fail to work.
What I did was firstly test the battery under load and discovered that the cell was a bit low. It was a fresh battery but it is a good idea to turn the camera off after shooting in case the is a slight current draw when the camera is idle (?) . I replaced the battery and traced the voltages through the body to see if it was getting to some of the contacts such as the onces on the meter prism which has LEDs to be lighted. I also used an ohm meter to check out continuity- everything seemed to be in order. I then cleaned all the contacts including the battery terminals withl alcohol and made sure everything was dry and clean.
Now- everything works. The camera was turned off overnight and the battery has lost no voltage when tested under load..
This camera is equipped with RB lenses which have no electrical contacts and therefore the camera and lenses can't "communicate" so the meter will not work with theses older lenses.
Ed
Apr 09, 2008 | Mamiya Photography
Turn it on
Actually, you don't have to "turn on" the Vivitar V3800N. Just be sure it has working batteries in it (takes two small alkaline button cells, unscrew the cover on the bottom with a coin--put new cells into the holder with the + side up). If the batteries are working, when you press the shutter button halfway down, you should see an LED light up in the right side of the viewfinder. This is the readout for the exposure meter: a red + indicates overexposure, red - is underexposure, a green dot means you've got the exposure correctly set. You just change the shutter and aperture settings until you get the green light, then shoot. When you load film, you also need to set the ISO film speed setting. Pull up on the outside ring of the shutter speed dial and turn it until the number in the window is the same as the ISO number on the film you are using. The batteries, by the way, only power the exposure meter. The shutter is fully mechanical (just like in the good old days), so you can use the camera without batteries if you have a separate exposure meter, or if you can estimate exposure. Film loading is about like any other 35mm manual camera: pull up on the rewind knob to open the back; insert the new cassette of film on the left and pull the film leader out a couple inches and hook the film to the takeup reel on the right. Move the film advance lever a bit to be sure the film is firmly hooked onto the reel, then close the back. Wind and shoot three shots to get the exposed film leader out of the way, and then start shooting. When the film is finished, press in the rewind button on the bottom of the camera and rewind the film into the cassette before opening the back of the camera. Good luck--these are pretty good little cameras. We buy a lot of them for the photography program where I teach, and I've only ever had one with a problem (meter was bad). The lenses are quite good, and they are "K-mount," which means that any Pentax bayonet lens, and gazillions of others with this mount, will all fit. --Michael R. Sawdey
Sep 03, 2007 | Vivitar V3800N Zoom 35mm SLR Camera
Nikonos V 35mm Point and Shoot Camera Logo
308 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
