Question about Philips 50P8341 50" Rear Projection Television
Philips 50P8342 Hello, I have a Philips 50P8342 that I received from a friend for free. I knew it had problems so I checked on the internet for common problems. The search pointed me in the direction of the SSM so I removed it and cleaned the gold-fingers on the SSM and also cleaned the connector contacts. I put it back in and didn't see any change so I started investigating further. I have 3 known symptoms: 1) The tv has a problem with convergence. The center of the screen is OK. But in all four corners of the set (about a 8" square ), I see ghosting (double images). Sorry I'm not a tv repair expert so I hope I'm using the correct terminology. I entered the DCM mode to set convergence and I notice that the G, R, and B horizontal and vertical grid lines do not hold a straight line at the corners. I'm able to adjust convergence and align the center for G, R and B mostly but the lines in all four corners are drastically off. Is this symptom circuit related or non-circuit related (i.e. mirror or CRTs)? 2. When the tv has been on for a while, the sound begins to cut in and out. 3. When I entered the SAM mode for the first time, the ERR buffer was 31 33 32 7 0 0. I noted it and erased the ERR buffer. Now, when I go into the SAM mode I consistently see an ERR code of 30 "CSP i2c error". I have not done any signal probing yet. But based on the ERR code, the fault seems to be either the SSM and/or the convergence processor (circuit related). Thanks for reviewing my post.
  • awilliams Dec 14, 2007
    Thanks for the prompt response troylove11. For clarification, are you referring to the SSM module?
    Genius:
  • 1,153 Answers
PTS 18008447871 can repair the board and give a price
Posted on Dec 13, 2007
Need help to correct Incredimail send/receive mail problem?
Hello friend,
I Guess this is common problem you don't need to worried about that you just have to reset all mails setting by following these steps.
When your Incredimail window is open click on the tools that's mention on top of Incredimail window, then go to your @email account and add E-mail you want to receive mails from then reconfigure email account automatically or manually you can also use user E-mail users like Gmail, Yahoo, AOL, Roadrunner, hope it'll work for your sending and receiving trouble because this information is out from Incredimail support website
Jan 18, 2017 | IncrediMail Computers & Internet
I can not receive the free spins from friends.
what are u using to access the internet? IE internet explorer or firefox? if ur using IE try firefox sometimes i find it wont even load in IE.
Aug 02, 2012 | Evermoremedia DoubleDown Casino
50P8342 tv TURNS ON BUT THEN TURNS OFF AFTER A FEW MINUTES, ALSO AT TIMES IT FREEZES... WHAT COULD IT BE?
This set has an SSB module, they are notorious for causing the set to fail with strange symptoms like the freezing up you are experiencing. This board needs replaced it is a very small board about the size of a deck of cards, mounted vertically on the left hand side. The cost of this board is usually over $200.00. I have worked on many of these, and one thing you need to be aware of is that i have received new board in that were defective, this was a chronic issue, and if you buy a board make sure you can return it, if the tv begins to have other strange problems most likely that board you purchased is defective as well. This is a big issue with this set including the repeat failures of this board
Nov 20, 2009 | Philips 60P8341 60" Rear Projection...
I have a Philips 50p8342 television. When it is
Sounds like you are tripping your crowbar circuit. This is most commonly caused by one of the Red Green or Blue brightness adjustments, adjusted too high. The crowbar circuit protects your high voltage guns from getting damaged. I know this because I just did this myself. My adjustments were behind the lower rear panel in a small box screwed to the chassis. There are 6 tuning pots on mine. 3 for focus of the RGB and 3 for brightness of the RGB. The focus ones didn't seem to have any effect on the crowbar circuit. However, by turning the brightness down on each of the RGB pots I could get the T.V. to stay on indefinately.
Oct 18, 2009 | Philips 60P8341 60" Rear Projection...
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
Philips 50p8342
By all means get rid of the set! Even if you spent the time and $ fixing you may have further trouble down the road from corosion. Time to buy a new set. NAME BRAND JAPANEESE ONLY! OH, dont forget to buy the extended warranty.
Nov 01, 2007 | Philips 50P8341 50" Rear Projection...
No picture or sound
sounds like the PTV Small Signal Board.
Jul 22, 2007 | Philips 60P8341 60" Rear Projection...
I have a 50P8342 with simular problem
My tv was doing some of the same type things I touch one of the manual buttons ont tv and the channel would change or the volume would go up or down. I changed the control board behind the manual buttons on the face of the tv and now it works fine with or without the remote. the part no. is 313501707611 go to sears web site type in this number and order it. this part will come up as 60P8342 but thats ok becouse the 50P8342 and the 60P8342 use the same part number I know I have both models and changed them both using the same part and part number.
Nov 19, 2006 | Philips 60P8341 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
323 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
