Sony DVP-SR200P DVD Player
Problem for Sony DVP-SR200P DVD Player
Hi, I need to unlock
By humberto_sil on Sep 19, 2009
Hi, I need to unlock the dvd player Sony DVP-SR200P to play all regions.thanks
Comments:
Sep 19, 2009
- didn`t work. After to enter with 2812 nothing happened. I`m not able to chat with you. Is it possible to reconnect ?
Sep 19, 2009
- I had already tried both procedures. The second one was working until the step "Try 3 or 4 times. I tried much more than this and nothing happened. I never got both lines with 00000
Sep 19, 2009
Sep 19, 2009
- When I fill the first line with the code 24570 and I confirm, automaticaly goes to 2nd line and it´s already filled with 00000. My doubt is what do after this. I pressed 0 and got back to the main menu. Then I pressed 2 and 4 again to go to the same place. I filled again with 24570 and confirmed. Go to the second line that is already filled with 00000. And so on. Tried this way more than 10 times. Not sure I´m doing the right thing
Sep 19, 2009
Sep 19, 2009
- I tried other region and it is still locked.
Sep 19, 2009
- no. not working for other regions
Sep 19, 2009
Sep 19, 2009
Sep 19, 2009
- I bought one month ago. The firmware main version is 1.005 :(
Sep 19, 2009
Sep 19, 2009
- still not working.
Sep 19, 2009
- ok. thanks. :(
Sep 19, 2009
- ok. thanks. :(
Best Solution
posted on Sep 19, 2009
Helpful)
njvinod
Rank: Wiz  Televisions & Videos  Expert
Rating: 85%, 418 votes
THere was some problem, with the chat...I was not gettin gyour messages
1.Switch on the player
2; Pop open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
7. Pop in a DVD and enjoy!
Comments:
Sep 19, 2009
- Leave me comment, If it doent work..Ill give you some other codes..Ill solve your issue.Here
Sep 19, 2009
- Even try this, if that doesnt work
With player off, press Display after Top Menu After Clear and last On. Imediatelly your player appear Options : Choose number 2 , Drive Manual Operation; and after press 4 Tray Aging Mode. Put the CODE 24570 and confirm , go to second line and put 00000. Try 3 or 4 times , and when the 2 lines fix the numbers 00000, will be Ok , your player to use. I hope to help
Sep 19, 2009
- Think there was some issue with the Fixya server...it wont be possible, But ill try to solve your issue here.....Have you tried both the steps...
Sep 19, 2009
- Have you tried more than 3 to 4 time because, it should be tried till the lines get 0000
Sep 19, 2009
- PLease leave me comment after trying the second step multiple times
Sep 19, 2009
- DId any step solved your problem, PLease leave me comment as we chat..So im here will assist you immediately in solving your issue
Sep 19, 2009
- I think your dvd would be unlocked,Please try playing other DVD region and comment whether it works
Sep 19, 2009
- Is it working..Im still waiting for you r response
Sep 19, 2009
- Give me a minute,Ill try to check the codes an d put again...Sorry for making you to wait..
Sep 19, 2009
- The DVD HACK Guide says,SONY SRP DVD player containing the firmware of year 2008, cant be unlocked using the Remote code, You need special hardware hacking, Which can be only hacked by special hardware...
May i know, when did you purchased the DVD plyer, Is it older than 2008 or in or after 2008
Sep 19, 2009
- Try doing the power cycle once by switching the player off and switching on again
Sep 19, 2009
- Im very sorry sir, it contain some advance security mechanism, which cant be hacked normally..SO you need special harware to hack its region...ITs not that it cant be unlocked, it can be..But you have to take it to some DVD unlock center to do that...
Sep 19, 2009
- IT cant be unlocked with that code..AS your device contains advance firmware
Sep 19, 2009
- Thanks for using Fixya!, Hava a pleasant day!
Sep 19, 2009
- As i gave you the solution, Please spend some time and please leave me good feedback for the chat session, Please
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Sony DVP-SR200P DVD Player
Questions and Unsolved Problems for Sony DVP-SR200P DVD Player
Do you recommend Sony DVP-SR200P DVD Player?
Answer
Answer
We got a new dvd player today and all the cables are hooked up correctly and it is plugged in and... (More)
Answer
how to find the code for my tv which is not listed in the book i have an apex tv and sony dvp sr... (More)
Answer
connecting this unit to tv and at&t u-verse box
Answer
sony dvd player DVP SR200P need to unlock region codes
Answer
hi there, can anyone help me with a region unlock code for a sony dvp-sr200p? a little desperate as... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in , IL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
