Question about Smeg 18 in. DWF410SS Slim-Line Free-standing Dishwasher
Residue left leaves food residue on items on top rack ,looks like the spray arm under the rack is not spinnings.
  • 640 Answers
Make sure the screens in the unit are clear,also check that the wash arm holes arent obstructed or the arm isnt cracked at the seams.let me know.also is the unit getting hot?
Posted on Dec 13, 2007
Items in the bottom tray are clean; items in the top are not.
The first thing to check is whether the spray arms are clogged up. Small, hard food particles such as pepper seeds can block the holes. Some spray arms can be removed very easily for cleaning. Our old Kenmore spray arm needed a star-shaped bit. Check the overhead spray arm as well as the ones under the racks. You might also try running Lime-Away through if the inside looks clogged up with calcium deposits.
In our old Kenmore, we had food residue on the top rack when the grinder blade was chipped, broken or obstructed by an olive pit, a date pit or a cherry stone. Don't know why the top was worse than the bottom. A new one cost about $25 at that time and was not to hard to replace, but it is a poor design, since it is nearly impossible to keep such things out of the dishwasher. We replaced the grinder three times in 5 years.
Even though modern dishwashers brag that you don't have to rinse first, it is helpful to knock off seeds and pits that can cause trouble. To save water, have a small vessel of water--perhaps a pan you are soaking--and use a brush to quickly swipe each plate or bowl before loading.
Jul 26, 2011 | KitchenAid Dishwashers
Not cleaning leaving residue - top sprayer doesn't spin
check spray arm for food residue build-up,if its clean then it may be the water feed conduit from the bottom tub up to the arm on top that leaking by and losing water pressure
Oct 14, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
Not cleaning properly, food residue left mainly on top rack items
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 20, 2010 | KitchenAid 24 in. KUDI02CR Built-in...
I have a bosch dishwasher, SHU535E05UC/14. The
the spray arms are not rotating check they spin freely if they do remove them and clean any residue food deposits blocking holes for water spray.
Jan 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishwasher doesn't clean properly
Lots of possibilities...
1. the sprayer arm might be sticking and not moving, or moving very little. Check to see if you can spin it by hand. Listen when the machine is running and you should hear the sound of the spray changing as it rotates. Check for items that might be jamming the arm like silverware, cups, jar labels, etc.
2. the little holes in the sprayer arms could be clogged. Need to remove the arms and clean them.
3. If it has a spray arm in the top rack, check to see that the piping for that is not broken or missing any pieces.
4. Any filter screens inside the plumbing could be clogged. This would slow down the spray and result in the dishes not getting rinsed properly. Check the inside of the machine for any foreign objects (see #3 above).
5. The machine might not be emptying between portions of the cycle. After the wash cycle, see if it is draining by either checking for water coming out of the drain hose or by opening the machine before it should start filling up for the rinse cycle.
6. Machine could be overloaded. Or loaded with extremely dirty dishes. Or with foods that are hard to clean like grits or oatmeal.
7. The machine could be improperly loaded. Bowls or platters blocking the spray. Tall objects like glasses and jars should not be loaded into the corners of the racks. The corners do no get a lot of spray and tall items can end up dirty.
Dec 22, 2009 | Neff 24 in. S5555X0GB Built-in Dishwasher
My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Jun 20, 2009 | KitchenAid Dishwashers
Dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Top rack not cleaning and spray arm possibly not moving
Hello--our Kenmore Elite has been showing exactly the same symptoms.  Since it's under warranty I had a technician take a look at it, in fact he just finished putting it back together: problem was accumulated food and junk around the inlet filter to the pipe that leads to the upper racks.  You can only get to this area by removing the lower spray arm, filter assembly, etc. until you are looking at the sump/chopper area.  Any clogging should be self evident at that point.
This would be an easy repair for anyone with a few tools and the willingness to get into it.  Seems to be working very well.  We will be rinsing more thoroughly in the future...
Feb 25, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Jun 01, 2006 | Smeg 18 in. DWF410SS Slim-Line...
Smeg 18 in. DWF410SS Slim-Line Free-standing Dishwasher Logo
277 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
