Question about Sony Cyber-Shot DSC-F828 Digital Camera
Memory stick error
The battery icon flashes along with this code C:13:01
It also says Memory stick error.
I have three memory sticks, one which is brand new and they have all be reformatted to try and solve this.
I also have two batteries and they have both been charged.
Any thoughts on this would be helpful. thanks.
  • Anonymous Dec 29, 2007
    Hello
    I have got the same problem.
    It started when I used the memory stick to upgrade the firmware of my TV.
    To solve the problem I formated the memory stick (sony PRO magicgate 512Mb) in my PC and I also downloaded the formatter software from the sony site but it didn't work.
  • Anonymous Jan 17, 2008
    I have sporadically the same problem.When it occurs, a change of the memory stick does not solve the problem. I also went to a shop to let them check if the stick is defective (or maybe the adapter). In one shop a new stick worked, in another shop a new stick did not work.
    I assume that it is not really a problem with the sticks, but maybe a problem of the switch inside the F828 (which switches between Memory stick and Compact flash). When the problem occured last time, after two days all worked fine again (without any reformatting, so the formatting of the sticks does also not seem to be the source of the problem).
    When the error 13:01 occurs, it is even not possible to format the stick (since the error prevents the menue item format to be used).
    Helmut
This is a problem with the battery connector inside the camera. It is common to the DSC F717 and this camera. It's, unfortunately, a pro camera repair issue on the 828. It can be fixed DIY on the 717. I did it to mine and now it works fine.
Posted on Jun 01, 2008
Installed new film memory stick and new charged battery.......... screen flashes format error with several flashing symbols....help.
Hi, best bet, try formatting the memory stick first, then use with camera, format will create a FAT system, should work.
Mar 02, 2015 | Cameras
Memory stick error
Did you format the stick using the camera
if not then try that there seems to be a
problem when formatting with reader
Nov 19, 2007 | Sony Cyber-Shot DSC-F505 Digital Camera
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
Saving Music to Memory Sticks
Memory sticks, memory cards and even USB thumb drives all get attached by Windows as a drive. Pull up Windows Explorer (file manager on Mac). Navigate to My Computer level. THis will show all drives attached including hard drives, connected USB drives and connected memory sticks/cards. You may not be sure which is which unless the drive was labeled with the cards branding. One way to determine is go to lower right task area and click on the 'safely remove hardware' icon (green arrow). Select safely remove hardware from pop-up menu. Check the box for Display device component. This should populate the window above with the actual names of the devices along with the assigned drive letter. Now that you know which one, open Windows Explorer, navigate to My Computer level and the select the drive letter. You can drag and drop files to and from this window to take files on and off the memory card/stick/USB drive. You can also right click on the drive letter and choose properties to see how much room you have on the card.
Oct 11, 2009 | Electronics - Others
Memory stick error when camera is turned on
Hi
How about download the user manual from this link
http://www.docs.sony.com/release/DSCV1.pdf
and then, please read page 106 and follow the sugestions they have relative to your memory error.
Are you using the correct memory type recommended for your camera?
Did you insert the memory stick in correctely?
Is the metal part of the memory stick and the camera clean?
Did you accidently recorded video for a long time on the memory stick. The memory stick may be full.
Did you unlock the memory stick if it has one?
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 27, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Format a memory stick?
connect the memory stick to the computer. open (my computer) you will find an icon for the stick, right click on the icon then choose format.. a windows will appear, then you can format it normally.
Oct 02, 2008 | SanDisk 4GB Memory Stick Micro M2 Memory...
Memory Stick Error, PLEASE HELP!!!
Does any other Sony memory stick still work in your camcorder? If yes, means memory stick isn't match with this camcorder. Use Sony memory stick.
Jun 09, 2008 | Sony Handycam DCR-TRV20 Mini DV Digital...
Problem accessing memory stick
I had the same problem. I bought a 2 gig memory pro-duo with the adapter and it gave me that error even though it fit just fine. I then tried a 512 memory stick and a 1 gig memory stick and neither one worked it gave me the C:13:01 error code. So I found out the hard way that the camera will not read it. The Sony DSC-S85 will not take memory above a 128. Try the Lexar 64MB memory stick. I just bought 4 and they work perfectly fine.
Nov 02, 2007 | Sony Cyber-Shot DSC-S85 Digital Camera
Memory stick error
Try using another memory stick, or insert a confirmed good memory stick, if OK, the memory stick is defective, if the same error, try pressing reset at the back of camera, a small hole beside the the DC jack. if OK, then fine, if still the same, camera needs repair. thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Memory stick error
Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck
Sep 03, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-F828 Digital Camera Logo
192 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
