Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
COLOR PROBLEM ON MY PHILIPS 60IN MOD#60pp920217F
I KNOW U SEEN THIS PROBLEM BEFORE WHAT CAN I DO TO FIX IT AND WHERE CAN I GO TO GET PARTS FORM.(IF I CAN FIX IT MYSELF)
    President:
  • 4,402 Answers
Http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 14, 2007
I have way too much redness in my 60in philips magnavox television...I need to know how to adjust the color and brightness so that the picture shows better!!
Can you give me a model number, if this is a rear projection set you may have a crt/picture tube problem with the liquid. Is the picture cloudy looking and you can't adjust color or tint to make better or pull up menu and if see a glow or hallow around letters and people in picture?
Jul 08, 2011 | Televison & Video
My phillips model 60pp920217f
The two parts have the same pin-out but the 120 can handle more power. If you install the 110 version, expect it to fail rather soon. If you call the distributer from whom you recewived the parts, they will likely exchange them for the correct ones for the difference in cost plus shipping. It won't hurt to ask. Check in the area of the ICs for open pico fuses or open low valuied resistors. Either can cause the problem that you are seeing.
Keep us posted.
Dan
Jun 20, 2008 | Philips 43PP9202 43" Rear Projection...
We have a philips projection tv 60PP920217F we can not alighn the blue color the picture is concaved on bottom and top
This is a convergence problem and can be repaired by replacing the two STK-392-120 convergence chips and adjusting the set with the original remote control
I have specific instructions for this repair from start to finish.
SD TECH
Feb 16, 2010 | Philips 60PP9202 60" Rear Projection...
Broken Screen Phillips 60PP920217F
go to phillips.com/parts they should have them there
Aug 31, 2008 | Philips 60PP9202 60" Rear Projection...
60IN PHILIPS
Time to fix it !!. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms.SOme time SSB is defective ( small signal board, replaced it ) If you have questions? noetvs@embarqmail.com . Good Luck !!
Jul 13, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP920217F bows in on top and bottom
convergance amp ic are bad.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 28, 2007 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP920217F Convergence Problems
Sounds like you are on the right track, yes you need to change also the return resistors, they will be located close to the convergence amps you have replaced. There should be several resistors standing up around the IC's, you can lift one leg and check all resistor and the ones with same color should be the same resistance. Another way is to just replace all of them. I don't have a location for you but I have replaced a similar set 51pp9303h/17 and I think the boards are similar. So if you are this close then by all means replace all the resistors, You can go to MCMelectronics, Bluestar-online.com, Tritronics, etc. To get part and also you can buy schmatics on line. Don't quite remember site but you can search. I think it was 11.99 for downloading for my set. So hope this helps.
Sep 19, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60pp920217f Blinking Power Light
Call a technician. If fixed it is worth it for ~$200.
Jun 14, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
