Question about HP 1010 Plain Paper Inkjet Fax
Wont work I put in a new inkjet and now nothing happens I can't copy the cartridge doesn't move or anything. What can I do. Help it is our business fax.
  • 537 Answers
Here's the manual for your unit. It should have troubleshooting tips in it.
http://www.retrevo.com/s/hp+1010+manual
Posted on Dec 13, 2007
Doesn t recognise the color cadrige
Please follow the steps below to fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove the color cartridge from the carrier.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert the color cartridge.
7. Close the printer cover and check for any errors.
8. If the error continues to appear, replace the cartridge with a new cartridge or insert a different known working color cartridge to determine if it's a faulty cartridge issue.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 19, 2011 | Lexmark X2650 All-In-One InkJet Printer
Paper comes out black when printing and copying.
A. The drum is not being charged. The charger corona wire is probably broken or not making good electrical contact. The charger corona wire may be part of the toner cartridge. Try uninstalling and reinstalling the toner cartridge. If that doesn’t work, try another toner cartridge.
Please rate my help++++Thanks for using FIXYA
Jun 05, 2010 | HP LaserJet 3050 All-In-One Printer
Printer sat a year without ink cartidges, now wont print
Leaving inkjet printers alone for a long time generally results in the print heads getting clogged. Try cleaning them by following the steps on this page. If this does not work, you may need to replace them.
Good luck! :)
Feb 19, 2010 | HP Officejet 7130 All-In-One InkJet...
My HP C4150 is displaying "remove and check color cartage" it wont do anything until i open the entrance to the ink well... and after i do and i take it out, nothing happens
The color cartridge probably is defective the printer won't recognize it. Оften happens HP cartridge to overheat.Just replace the color cartridge with new one.
Oct 21, 2009 | HP Photosmart C4150 All-In-One InkJet...
Display message won't stop: Press Enter to align cartridges.
I honestly don't know how I solved it; I did everything your forum suggests at least two times (restarting, disconnecting, re-installing, etc), but nothing would work. After I got up the next morning (four hours sleep!), I did it all again, and this time it worked. I did two things differently that may have worked. Somewhere in the owners manual, it says to wait for quite a long time (like over 5 minutes--I don't have the manual with me now). Also, it says to NOT turn the printer on until AFTER installing the software. Those two little items may have made the difference, but the main idea of reinstalling came from you. Thanks!
Jun 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 not printing. Can't get out of "align cartridge"mode.
printer problem call up hp at 1-800-474-6836 and ask them for an upgraded printer which you will get at 50-60% cheaper than the original and its a factory new printer.But it is definitly not free.
What you have right now is a hardware problem and the printer is dying so change it fast while this offer is available
May 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp office jet 4255 printer not printing anything or copying
ok..first try to make a copy and check if it copies fine or not..
if it copies then hardware is working fine..
turn off the laptop and unplug the USB cable..
turn on the laptop and wait for 5mins and then connect the USB cable..once the USB cable is connected do not try printing..wait for the hardware to get installed..
and then go to the printers folder and check if the printer icon says 0 ready..if it says then try printing..that should work
Feb 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
HP business inkjet 1100
This very simple solution works on my Business Inkjet 1100.
1) Turn the printer off, then back on, to clear the error.
2) Set your computer's clock back to a date prior to the cartridge expiry date.
3) Print something, (any documents will do).
4) Set your computer's clock forward to the correct date and the printer should still print, and ignore the expired cartridges.
My 1100 re-checks the cartridges and dates occasionally, but not frequently (it has been about two months between checks) so you might need to repeat this process every two months or so until you have used up your expired cartridges.
This solution is much easier than dismantling the printer and changing/removing wires!
Sep 10, 2008 | HP Business Inkjet 1100dtn Printer
It just wont work
Move the ink cartridge carriage (the printhead) to the middle of the printer like you're going to change cartridges.  Take out all the ink cartridges.  There should be two black springs on either side of the printhead.  Remove these and the printhead should pop out.  Clean the nozzels (the little parts that squirt out ink) and reassemble.
If this doesn't work, then you'll have to replace the printhead.
Oct 28, 2007 | Brother MFC 3100C All-In-One InkJet...
Printing problem
The black cartridge printhead needs to be cleaned or replaced. Follow your printer manual instructions.
Mar 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP 1010 Plain Paper Inkjet Fax Logo
81 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
