Question about Dayton E52 Utility Heater
When i turn on the heater it just blows smoke
When we turn on the heater it blows out smoke and some kerosene comes out of the front of it instead of the flame that is suppose to come out. We have already tried to dry the spark plugs and other parts that we can reach.
  • 1 more comment
  • DANA2 Jan 21, 2008
    BLOWER RUNS FLAME TURNES ON AND OFF
  • TERRY GLASS Jan 28, 2008
    I HAVE( 5 ) 400,000 BTU DAYTONS ALMOST ALL OF THEM RIGHT OUT OF THE BOX FAILED WITHIN 1 WEEK, PUKED FUEL OUT OF THE FRONT AND STOPPED FIRING, GRANGER KEEPS REPLACING THEM, THIS IS GETTING OLD. I USE CLEAN FUEL, ANY SUGGESTIONS ??????
  • onegoodapple Jan 25, 2009
    i have the same problem but mine is a dayton 125,000 with the pack under neath fan. mine was working friday night, but when it started it blew smoke then ingited. i tryed to run it today and it blew smoke but never did light. i took top off and spark plug is working, fan is working, i got fuel up to end of pipe, and i got fuel coming out of front. question is, whats wrong????
    Scholar:
  • 90 Answers
If the unit has a high voltage transformer that ignites the flame. ie it has a heavier wire plugged into a spark plug or igniter. the coil is likely bad..... it should arc as soon as it is turned on. later models have a heater that gets very , cherry red, hot and that ignites the fuel. take the top cover off and you should be able to identify which you have. coil sets right under fan. one heavy wire and two light wires as the primary. light wires at about 12 ohms and heavy wire to chassis in the k ohms.
Posted on Jan 26, 2008
  • 625 Answers
According to desatech who makes reddy heat, the air compressor on the back of the fan should put out no more than 3.5 psi to the nozzle. you could also check the air path through the combustion chamber. sounds to me that the nozzle isn't atomizing the fuel but its coming out in a stream. the nozzle is supposed to make a conical pattern if the air pressure is correct.
Posted on Dec 14, 2007
Reddy Heater kerosene 110,000 btu . plup it in, fan runs, blows smoke out the front, leaks kerosene also from front, i have cleaned photo cell, replaced plug, cleaned filter and checked lines for cracks,...
Just because there is fuel & spark does not necessarily mean there will be combustion. The fuel must be delivered at the correct pressure, the correct volume, and must be delivered as a fog- not a mist.
My suggestions:
  1. set the pump pressure
  2. be sure the fuel filter is clean
  3. be sure no air leaks or vacuum leaks
  4. Desa recommended annual replacement of the nozzle. They wear out. When was the last time yours was changed?
More troubleshooting tips
Oct 20, 2011 | Reddy Heater-30-55,000 BTU Variable
Shuts down after about 30 seconds, blowing some smoke.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Heater turns off leaving lots of smoke and is hard starting
If this is a kerosene heater,the wick is most likely not adjusted up enough,or the wick is contaminated.The fuel could be contaminated also.Remove the old wick and replace it,and refuel it with clean kerosene,after you pour the old out.
Oct 14, 2009 | Heating & Cooling
HARD START AND BLOWING SMOKE
clean all of your filters and the spark plug and go back to useing K1 kerosene. Diesel fuel has a higher ignition temp. burns dirty and has a tendency to gel.
Jan 20, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Fan turns on starts blowing and a lot of smoke.
when you start it the smoke starts wright away it is not getting the right air flow takethe top part off and started see what it does if it stays running try to ajst. the fens ok .
Dec 26, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Blows cloud of smoke
thin your fuel mix with about a gallon of kerosene to 5 gallon of heating oil.could also be a semi clogged fuel line filter.
Nov 21, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton E52 Utility Heater Logo
464 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
