Question about IBM ThinkPad T20 2647 Notebook
Ibm think pad t20
Have replaced original hard drive with a new one. New one might have an operating system installed or might not. All we have right now is a screen with a blinking cursor. We see where we can access the Bio Utility Setup. Where do we go from here?
Pop a linux live cd (I reccomend PC Linux 2007) that is what I am using in my ibm t-21 laptop. It will load and run from the  cd drive, then install it to the new hard drive.  Ps. it will work with a belkin usb wi-fi internet access point.  Mine does
Posted on Dec 16, 2007
  • 537 Answers
Make sure your replacement hard drive is compatible in geometry (supported by your ThinkPad T20). Check and see if your BIOS setup utility has an auto-detect function.
It would be good if you knew the contents of your replacement drive. You said it might be installed, it might not. If there is nothing on the drive, the ThinkPad should report 'no operating system' or similar message, but it is possible that it might not show anything other than a blinking cursor
Posted on Dec 13, 2007
Blue screen says error loading,dont know how to recover with safe mode or how to activate safe mode.it is a think pad t20
Hi,well these should work for you,to get to safe mode,power up the system as the IBM thinkpad logo is about to be displayed press the F8 key just before the Windows loading screen comes up so as to get to safe mode.if it does not work try reloading the operating system using operating system disc.
Dec 20, 2010 | IBM ThinkPad T20 2647 Notebook
My IBM T20 Notebook is given me this message -PXE-E61: Media test failure, check cable- and then say -Operating System Not Found- ---- What do I do?
The error message PXE-E61 is Network card that try to conect this is because hard drive failure or Operating System
check on the bios if you can see the hard drive if you see the drive it could be the OS
hope it will help
Nov 02, 2010 | IBM ThinkPad T20 2647 Notebook
IBM T20 hard disk won't start, no display, and beeping
it may be drive issue,:
- replace the hd and cmos battery,
- change boot device priority in BIOS
to 1st: cd/dvd
2nd: hd
3rd: floppy or network boot or usb-boot
- exit BIOS saving changes: yes
- reboot from windows cd-rom for testing the cd drive
- try booting from new hd (if bios recognizes it,
then install operation system
- if still the same prob, see a technician about this issue
Jun 13, 2009 | IBM ThinkPad T20 Notebook
Put new hard drive in ibm 570
you need to install the windows operating system to the new hard drive and transfer your files ...
if you still have the CD installer that comes with it when you bought the computer..use the CD with label operating system..then after you install the windows..use the cd with label drivers and application
Mar 15, 2009 | IBM Computers & Internet
Thinkpad t20 trouble installing operating system
Three reasons why its not making it. One is a faulty hard drive, and even though you bought a new one it can still be faulty. Two is your Windows XP Disc is damaged but the most likely one is that your motherboards slot for the hard drive and/or more are faulty and is not working well. Run XP and choose 'Format Drive' and Install two partitions, one C Drive and D Drive giving each equal amounts and installing NTFS on one part and FAT32 on the other and see which one runs the best. If both fail, Replace your Hard Drive with the origional one where windows was shot and Format and do the same things as above with the partitions and NTFS and FAT32. If again it fails borrow another hard drive and again do the same things and again if it fails. Also since you said its difficult to make it to the part for partitions replace your CD Drive if the CD looks good and re run the boot disc. If all fails, replace your motherboard and give it all another go
Hope This Helps
Oct 08, 2008 | IBM ThinkPad T20 2647 Notebook
Ibm thinkpad t20 notebook
Bad connection from your hard drive to the laptops motherboard. ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/62p9631.pdf page 63 tells you how to remove the hard drive - I would take it out, clean the connections with rubbing alchohol, and FIRMLY put it back and see if it will come up then.
Apr 02, 2008 | IBM ThinkPad R51 Notebook
Could be a problem with the MBR or Master Boot Record.
It could be damaged. It's only a file system type problem not a hardware fault.
Have a look here.
http://www.ambience.sk/fdisk-master-boot-record-windows-linux-lilo-fixmbr.php
Mar 09, 2008 | IBM ThinkPad T20 Notebook
A21m IBM Think Pad type 2628
hi raceydave, u can better delete the extended partition which will be show in disk management it will be show as unallocated space then try to install linux
Dec 17, 2007 | Computers & Internet
Install hard drive for t20
So, what is it you want to do?
The hard drive on a T20 is in a slot on the left side of the unit, and it's cover can be taken off by removing 1 screw on the bottom just under the sound ports.
Hope that helps.
Nov 25, 2007 | IBM ThinkPad T20 2647 Notebook
IBM Thinkpad T20 - Model Type 264784U
I would say the hard drive is failing. But need to run a diagnostic on it to be sure.
If you would like to know where to get the ibm / hitachi hard drive diagostic let me know. It's free for download and you can get a bootable ISO image to burn onto cd. Allowing you to boot from cd in order to test the drive.
As far as replacing, you should be good with a 60gb or 80gb. Did it orginally have a 20gb in it? I would say for most people, 60-80 is way more than enough. Unless you have a ton of music or pictures.
Oct 22, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
269 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
