Question about LG enV VX9900 Cellular Phone
LG Front Display
This just started happening recently, when I plug in the cable to charge my LG Envy is starts out charging just fine but after a minute or so the screen turns black and show the time in big numbers. (Sort of like and old clocks that flipped over each minute). It ends up charging fine, but the screen has never done this before. Can it be fixed?
  • leisalu Dec 14, 2007
    So nobody knows what the problem might be?
My phone does that because I set it to. You or someone else must have set a screensaver.
Posted on Mar 18, 2008
    Problem Solver:
  • 7 Answers
Not sure what is wrong here. Obviously you or someone else has been playng with the settings of the phone and have changed things. Nothing is broken so nothing needs to be fixed.
Go into your; "Tools and Settings" Select "Display Settings" and you can schange things back in there
Posted on Dec 19, 2007
IPhone 5 was working perfectly, but when I plugged it in to charge, it didn't start charging. I could still use the phone. Now the phone died and nothing happens. Is the battery dead (as in broken)?
I would guess that you battery is fine, it is either your charger is not working or worse case your charger socket on you phone is damaged. Try connecting your iphone to your computer via the USB port and charging cable, if your phone starts to charge you know you have a problem with the plug side of your charging cable which is where your transformer is. Be aware that if your battery is totally flat it could take several minutes before you hear the beep from your phone to indicate that it is charging. If that doesn't work it could be your charging lead that is damaged so try charging with a different lead. If still no joy then you could be in trouble as the charging socket is soldered to the mother board and could be an expensive repair so fingers crossed it is only the charger that is damaged.
Jan 02, 2014 | Apple iPhone Smartphone
My daughters LG Xenon cell phone has been working fine until last night. She charged it, started working fine then shut off and won't come back on. I plugged it into the charger and it started working,...
battery short circuited change the battery and see that you do not charge overtime. second is recharge only after the battery has compltely been used from previous charging
Oct 14, 2010 | LG Xenon GR500 Cell Phone
My LG envy touch keeps redialing the most
This is because you might have enabled the automatic redail.Please put this to OFF so that it wont happen.
This option will be M enu--->settings---->Call settings
thanx
Jul 25, 2010 | LG enV Touch VX11000 Cell Phone
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Lg Viewty wont charge, wont start
try with a new battery your could have give up
May 27, 2009 | LG KU990 Viewty
MY ENV WONT CHARGE - even with pushing down
does it work when you plug it in on charge and then turn it on? if not its a battery replacement!
Feb 28, 2009 | LG enV VX9900 Cellular Phone
Envy charge port keeps breaking
Although today's electrinics are nicer to look at than things were 5 years ago, they're also more fragile. You must treat things like egg shells if you want them to last. I've had the same cell phone for 4 years, mi wife has been through 7.
Feb 17, 2009 | LG enV VX9900 Cellular Phone
Charging problem
I had this same problem, it's really irritating. Not exactly a full solution, but if you leave your phone connected to the usb for around 10 - 15 mins then disconnect it, remove and replace the battery and turn it on, it should have enough power to boot up, the just reinsert the usb and it should charge.
Dec 04, 2008 | LG Secret ? KF750 Cellular Phone
Charging problems
you might want to take it back to the store. that is a serious problem
Aug 04, 2008 | LG CHOCOLATE VX8500 Cellular Phone
W850i red light prob
When it is red light of death, it either means the bootloader of the phone is faulty (after uploading dodgy firmware updates), or the battery is too empty to start-up, let alone display charging progress. In your case you need to leave the phone charging even with the red light flashing and it will be fine. Give it a few hours connected to the charger.
Mar 14, 2008 | Cell Phones
LG enV VX9900 Cellular Phone Logo
155 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
