My rca proj. 52in... clicks off and on also switches channels...
It turns off and on... channels change on thier own...picture and sound is great.... when i first turn it own it was fine. after an hour it started doing that. what can i do to fix it?
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Check menu to make sure a signal is present. try video 1 with a external video source such as a VCR. If this produces a picture check for tuner signal by hooking the VCR to the antenna and tuning to channel 3 or 4. If their is no picture check antenna connector on back of set for looseness. If loose resolder antenna connector in tuner. If all these test fail the tuner may be defective and will require replacement.
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
