Question about Acer Aspire 3100-1405 Notebook
Help with my acer peace of s___
Thin white line (hoz) across screen (gets on my freaking nerves) this is after i bought it DOA and had to use mini PE to get hard drive to work and then loaded VISTA 5 times and finly it loaded without a error. i have a new hard drive comming but i cant get rid of white line 4 inches from bottom of screen
    Sergeant:
    Champion:
  • 243 Answers
Looks like a faulty screen as other guy said in other post :(
Posted on Jan 06, 2008
Why are there white lines on my screen?
If you bought it less than two years ago and still have the receipt, you should be able to exchange the device for a new one. Alternatively, you can go to your local tablet service and ask them to fix it.
Jun 29, 2014 | Acer Iconia B1-710
White thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Feb 18, 2010 | Dell Inspiron 9100 Notebook
White lines on screen and flickering
I think this is the problem of LCD.if it is then u should go to nearest service center .
Sep 25, 2009 | Acer Aspire 5920-6727 Notebook
A white line across my screen
A chip died in the LCD screen. Definitly take it back or contact the manufacturer for a warranty replacement.
Jan 05, 2009 | Dell Inspiron 1501 Notebook
Lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Aug 24, 2008 | Acer Aspire 4315 Notebook
It could be one of three things, the first two could be an easy fix, the last one calls for a qualified repair person and could cost you
-first, The lcd cable assembly is loose, make sure it's seated properly. if problem still exists try to Disconnect the monitor cable from the computer and turn the monitor on leave it plugged in to the electric socket.it will display a diagnostic colorbar are the lines still there. if not your problem might be a cable or video card. if they are still there have a technician evaluate the monitor.
-second, The inverter card may need to be reseated
-last, The lcd has a thin line crack and needs to get replaced
It would be helpful to know about the inner workings of an lcd screen and how to access them. It shouldn't be to difficult if your computer savvy. I want to caution you about getting shocked. an lcd still has power stored in capacitors. you should be able to drain those capacitors by leaving the monitor on and unplugging it from the electrical plug wait 10 sec or until all lights go out on the monitor.
If none of this works then Your monitor is defective, and nothing you can do to fix it... Call where you got it from for a replacement
Jul 11, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Thin white line (hoz) across screen (gets on my freaking nerves) this is after i bought it DOA and had to use mini PE to get hard drive to work and then loaded VISTA 5 times and finly it loaded without a...
A Few things you can try,
Updateing Graphics Drivers, Check Connections, Adjust resolution and refresh rate, Connect to another monitor to rule out GPU and Software issues.
Dec 13, 2007 | Acer Aspire 3100-1405 Notebook
I got the same problem, I'm going to return it to the store today...
Nov 27, 2007 | ASUS VW192S Monitor
Acer Aspire 3100-1405 Notebook Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
