Question about Dirt Devil Easy Steamer Upright Wet/Dry Vacuum
Wet vacuum not sucking up water
New Dirt Devil Easy Steamer Carpet Shampoer, not vacuuming up all water put on floor. any trouble shooting ideas?
  • 1,673 Answers
Re: wet vacuum not sucking up water
Usually when these units don't pick up the water, there is a seal or gasket missing or out of place. But you have a years warranty on this, maybe you should take it to a warrenty shop and have it checked.
Posted on Jan 29, 2008
Make sure the removable clear plastic tank part is properly seated and locked in. It will lock in even if it is not seated properly.
Posted on Feb 07, 2008
0 characters
3 Points
Dirt devil carpet steamer diverter valve not releasing for furniture attachment
Hi there! If the trigger or valve are sticking this can be an indication that the valve may be clogged with soap residue. Try soaking the trigger end in warm water for a few hours. When you use the hose again, be sure to prime the trigger by pumping it about 30 times then squeezing it for 30 seconds to get the solution to flow. Hope this helps!
Jun 22, 2014 | Dirt Devil Easy Steamer Upright Wet/Dry...
Unclog steamer so it will suck water?
To unclog any sort of water clog mix white vinegar 1/3 cup, with 2/3 cups of water, Than pour mixture into suction opening and let lie for about 5 minutes.
May 15, 2014 | Dirt Devil CE7000 Easy Steamer Upright...
Dirt devil easy steamer does not steam
have you put water in it, and that it does not leak out does it get hot
Oct 04, 2011 | Dirt Devil Easy Steamer Upright Wet/Dry...
I have a dirt devil featherlite carpet shampooer. It has been a great one for about five years without any problems. I need to know if anyone knows where I can find the replacement filters?
Hi There,
We actually do carry the foam filter for your Dirt Devil Featherlite (also manufactured as the Easy Steamer) carpet cleaner.
According to the Dirt Devil parts diagram for the CE6000, your machine takes the following foam filter. Here's a direct link to the filter on our website:
Dirt Devil Featherlite, Easy Steamer Foam Filter Part# 1-700750-600
Here's a link for the parts diagram for your Dirt Devil Featherlite CE6000 carpet cleaner. This will give you all of the part numbers, and drawings for each part on your machine should need any further parts:
I hope this helped. If you have any further questions or concerns, please feel free to use the comment field here on the repair page to contact me, I'm always happy to answer any follow up questions.
If you found this repair helpful, please be so kind and rate the repair helpful and / or leave feedback for me. Thanks so much!
Chris Jones
Apr 21, 2010 | Dirt Devil CE6000 Featherlite Wet/Dry...
I have a dirt devil carpet steam cleaner. model CE6300HD. It is not suctioning up the excess water. This model does not have a belt.
I took the advice on the chat site and checked the tightness of the gaskets on the bottom. They were not secure. Once I fixed that all was well.
Jan 30, 2010 | Dirt Devil Easy Steamer Upright Wet/Dry...
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
Dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Mar 27, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Ok, perhaps I am an idiot!
If you go to this URL: ...and enter the model number for your machine, then you can download a users manual. I would just give you the exact URL for the user manual, but I don't know your model number. If this helpful to you, please leave a good rating. Thank you! ;)
Aug 13, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil Easy Steamer Upright Wet/Dry Vacuum Logo
811 people viewed this question
Top Dirt Devil Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
