Question about Acer Aspire 3100-1405 Notebook
Thin white line (hoz) across screen (gets on my freaking nerves) this is after i bought it DOA and had to use mini PE to get hard drive to work and then loaded VISTA 5 times and finly it loaded without a error. i have a new hard drive comming but i cant get rid of white line 4 inches from bottom of screen
  • scott baker
    scott baker Dec 13, 2007
    you can see the white line in my first post about the bios
  • scott baker
    the white line is still there its ontop of the screen becouse i see it ontop of the pointer and not on a externel screen (i hooked up a desktop monitor and its not on it
  • 27 Answers
A Few things you can try,
Updateing Graphics Drivers, Check Connections, Adjust resolution and refresh rate, Connect to another monitor to rule out GPU and Software issues.
Posted on Dec 13, 2007
  • Jason Bell
    Jason Bell Dec 13, 2007
    Sounds Like a bad resister. Their is a row of surface mount resisters on both side of the LCD if one blows you get lines not much you can do. I have one blown pixel on the left hand side and it drives me nuts. Sorry
  • Ben Peacock
    Ben Peacock Apr 27, 2014
    Replace the screen :)
2 Suggested Answers
  • 243 Answers
SOURCE: help with my acer peace of s___
Looks like a faulty screen as other guy said in other post :(
Posted on Jan 06, 2008
White thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Feb 18, 2010 | Dell Inspiron 9100 Notebook
A white line across my screen
A chip died in the LCD screen. Definitly take it back or contact the manufacturer for a warranty replacement.
Jan 05, 2009 | Dell Inspiron 1501 Notebook
It could be one of three things, the first two could be an easy fix, the last one calls for a qualified repair person and could cost you
-first, The lcd cable assembly is loose, make sure it's seated properly. if problem still exists try to Disconnect the monitor cable from the computer and turn the monitor on leave it plugged in to the electric socket.it will display a diagnostic colorbar are the lines still there. if not your problem might be a cable or video card. if they are still there have a technician evaluate the monitor.
-second, The inverter card may need to be reseated
-last, The lcd has a thin line crack and needs to get replaced
It would be helpful to know about the inner workings of an lcd screen and how to access them. It shouldn't be to difficult if your computer savvy. I want to caution you about getting shocked. an lcd still has power stored in capacitors. you should be able to drain those capacitors by leaving the monitor on and unplugging it from the electrical plug wait 10 sec or until all lights go out on the monitor.
If none of this works then Your monitor is defective, and nothing you can do to fix it... Call where you got it from for a replacement
Jul 11, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Thin line across computer screen
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Mar 08, 2008 | Gateway FPD1975W 19" LCD Monitor
Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
Feb 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Acer 5100 Has no screen
It sounds like the mainboard or CPU died. Generally the hard drive is fairly easy to remove, look on the bottom or the side for a screw labeled "HDD", which should uncover the hard drive area.
Feb 25, 2008 | Acer Aspire 5100 Notebook
Help with my acer peace of s___
Dec 13, 2007 | Acer Aspire 3100-1405 Notebook
I got the same problem, I'm going to return it to the store today...
Nov 27, 2007 | ASUS VW192S Monitor
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Acer Aspire 3100-1405 Notebook Logo
416 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
