Question about Daewoo Televison & Video
Disc finalisation to enable to play on any DVD player
I want to finalise my DVD+R disc in my Daewoo DF4501P DVD Recorder+VCR. I have followed the instructions that came with the machine I.e.
1) Press SETUP
2) While "Disc oper" is selected press ENTER to go to Disc Op page
3) Use up and down buttons to select "Finalise" menu.
This is where the problem occurs the up and down buttons do not move the selection up only down to the exit selection.
Can anybody help
  • thirkellc Sep 28, 2008
    dvrt-40.dont know how to finalise dvds
3 Suggested Answers
  • 59 Answers
SOURCE: How to finalise on my DVD recorder?
 You will need to finalize them with the dvd recorder, it may also refer to it as closing the disk, it may be a button on the remote but more than likely it will be an option in a menu.....I can't seem to find a manual for it right now, If you have one you may want to read through it , thats how I found out how to finalize dvds with my philips. I'll try looking for a manual again later but right now I have to go to work so I'll get back to you on this.
Posted on Aug 09, 2008
  • 236 Answers
SOURCE: how to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Posted on Feb 09, 2009
How can I show my DVD-R(Memorex) on my televison?
I assume you mean that your current DVD player won't play this DVD?
There are 3 reasons that it won't play. One that the disc is faulty and therefore won't play on any machine. Two that the disc has a scratch or has marks on it. You can look at ways to clean the disc on-line!
3 That it was not finalised on the machine that it was recorded on. If you current player is a + machine it won't play the disc if it is unfinalised. You will need to use the old machine to finalise the disc or another "-" disc recorder to do it - if it will accept the disc! Otherwise if the old DVD recorder is no longer with you, then your only hope to save the disc is to find another model of your old recorder to do it on. If it was a common model someone might let you finalise the disc!
Feb 21, 2013 | Panasonic Original Pansonic Tv Vcr Dvd...
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
I have DVR19 DT, DVD?s I have burned will not play
The disc needs to be finalised. Unfortunately, my player didnt come with a manual. Can someone post how to finalise a disc, step by step.
Thanks
May 02, 2010 | Toshiba DVR3 DVD Recorder/VCR
When I record a dvd on my vr375 it will not play on my DSE dvd player .I am useing a Sony -RW DVD
before the disc will play on other players, you need to "finalise" the disc. Finalisation ensures compatibility with other devices. Go into the "Setup" menu, and look for "Disk Manager", there will be a finalise option. select the option, and after approx. 3mins the disc will play on other players.
Jul 18, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
DVDs from DVR don't play on any other DVD player
yes when you have finished the recording and preferably when the disc is full the disc must be finalised to be compatible with other players but be aware if you finalise a disc you cannot record on it anymore
Mar 10, 2009 | Philips Magnavox DVD/VCR Dual Player
How to finalise dvd recording
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Unable to finalise disc after recording
check the net download CD Roller very good program that finalises DVD cd etc wth recover options very cool! program
Dec 05, 2008 | Toshiba RD-XS25 DVD Recorder/HDD Recorder
Emerson EWR20V5 DVD Recorder/ VCR Combo
didn't realize had to finalise the disc after recording.
May 26, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Finalise disc
You need to put the disk back into the recorder, select the finalize function from the onscreen menu, and follow prompts. Do you have an owners manual for the unit?
Apr 22, 2008 | LG RH177 DVD Recorder/HDD Recorder
Televison & Video Logo
112 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
