Question about Xerox Phaser 7700 Laser Printer
Ram Error message
I have a Xerox Phaser 7700 that has sat for a while. When I recently tried to turn it on I received a "RAM ERROR" message. I have tried resetting the machine without success.
  • 35 Answers
Have you tried reseating the ram?
Posted on Dec 13, 2007
Hello, I have a xerox 7700 dx machine. Since moving the machine to new premises, when turning it on, I receive the error message, "Error 30 accumulator belt home position took too long" and it doesn't...
The error is caused by the home sensor for the accumulator belt not finding the home position of the belt. Since the error occured after a move, toner probably contaminated the sensor. Use canned air and blow out the sensor. Manual @: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
to locate the sensor. The other possibility is that the accumulator belt bit the dust. Parts a vailable at: http://www.lpscomputer.com/p-2993-1-016-1889-00-accumulator-belt-assembly.aspx
Apr 07, 2010 | Xerox Phaser 7700 Laser Printer
XEROX PHASER 7700 ERROR 11
Error 11, laser unit polygon motor failure. If this fault reoccurs 3 times successively the 7700 . enter diagnostics and clear tech rep fault and clear this 09-380, 09-383.
Oct 26, 2009 | Xerox Phaser 7700 Laser Printer
Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Mar 24, 2009 | Xerox Phaser 7700DN Laser Printer
Xerox phaser 7700 error 11
man...
listen .. you is with error
go listen cradle of filth the heavy metal :)
good bye
see you later
Oct 16, 2008 | Office Equipment & Supplies
Xerox Phaser 7750
There is a motor in the laser called the polyogon motor, It turns the mirrors in the laser.
It most likely is not starting fast enough.The laser isnt that hard to remove. But if it has failed, it is pretty expensive.
Let me know if you want to attempt to pull it.
Sep 10, 2008 | Xerox Phaser 7750DN Laser Printer
Phaser 6250 "Ram error" (?)
TRY FIRST (Solutions without parts):
For a continuous RAM Error message, try cleaning RAM contacts and reseating RAM.
NOTE: Third-party or generic RAM is not covered by warranty or service contract and should be removed for troubleshooting purposes.
TROUBLESHOOTING TIPS AND HINTS:
Replace RAM. If problem is not resolved, replace the Image Processor board. Please Note:
Intermittent 6250 RAM Errors can be resolved by replacing the Print Engine Board and EEPROM, remembering to Save/ Restore in Diagnostics.
Apr 15, 2008 | Xerox Phaser 6250DP Laser Printer
Phaser 7700 not booting up
a yellow line is comming on both sides of the printout when i print using my phaser 7700
Mar 20, 2008 | Xerox Phaser 7700 Laser Printer
Xerox printer error
The answer can be found here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
You must manually reset the Belt Cleaner life after replacing the belt cleaner.
Resetting Belt Cleaner Life
  • Resetting the belt cleaner life is to be performed only if the Belt Cleaner Assembly was defective and or the assembly is replaced before an end of life or near end of life message. Not to extend the life of the assembly. Doing so may cause premature failure of other internal printer components.
  • The printer will prompt the user to reset the life counts if the assembly is replaced after receiving a Replace Belt Cleaner Assembly or Replace Belt Cleaner Assembly Soon message.
note_image33x30.gif    Note: If the main Menu does not appear on the front panel screen and only Replace Belt Cleaner Assembly is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Belt Cleaner life:
  1. Press the cancel button several times to flush processing jobs from the printer.
  2. If you do not receive access to the front panel menu by doing this, then power off the printer and disconnect Ethernet, parallel or USB cable from the printer.
  3. Turn the printer back on, and while it is powering up, immediately start pushing the cancel key repeatedly until you receive access to the front panel menu.
  4. If the printer menu appears on the front panel screen, follow the instructions below to reset the Belt Cleaner life if the printer didn't prompt you to reset it:
  1. With Menus highlighted press OK.
  2. Press the Down Arrow and scroll to Supplies Info Menu.
  3. Press OK.
  4. Press the Down Arrow and scroll to Exit at the bottom of the menu tree.
  5. Now scroll up to Reset Belt Cleaner Life
  6. .
  7. Press OK.
  8. Reset Belt Cleaner Life NOW is displayed.
  9. Press OK to reset the belt cleaner life.
Mar 08, 2008 | Xerox Phaser 7700 Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 7700 Laser Printer Logo
640 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
