MOTHER BOARD NOT FITTING
I have got a motherboard and a casing
the problem is that my mother board is not fitting in the casing its edge which touches the CD ROM by about 2 inches
i can not buy another casing nor a mother board
please help
  • ashir Dec 13, 2007
    THANKS
  • 34 Answers
Well i had the same problem... i got a new pentium 4 board but it could not get fitted in the casing.... so what do you do is take the casing to a welder.... he will cut off a piece of metal which is resisting the mother board... The maximum loss is that 2 slots of CD ROMS will become obsolete and i think you dont need that....so have fun
Posted on Dec 13, 2007
Hello I currently have elitegroup PM800M2
The motherboards have standard screw holes. This is something like "one size fits all". You will be able to mount any motherboard in that case.
Jul 13, 2010 | EliteGroup PM800M2 Motherboard
MOTHER BOARD FOR CPU RUNNING WINDOWS XP
1.0 verify first your processor first so we can work what mother board will fit to your processor,
2.0 if your processor is bigger than pentium 4,
3.0 windows xp will definetly run smoothly..
4.0 Thanks!
Jul 15, 2010 | Intel Motherboard
HOW TO INSTALL MOTHER BOARD
These general instructions are intended to supplement or simplify some of the information in your motherboard manual Step 1 Make sure to read the manual that came with the motherboard - instructions differ for each one.
  • Step 2 Ground yourself with any professional grounding equipment you have. Otherwise, ground yourself by touching the computer power supply.
  • Step 3 Place motherboard on its anti-static bag.
  • Step 4 Configure motherboard: Set jumpers or DIP switches for CPU, voltage(s), and bus speed, if necessary. If your motherboard is configured by software, you will need to configure it after you complete the physical installation.
  • Step 5 Position motherboard in case. Line up holes in board with holes in case.
  • Step 6 Insert spacers, plastic stand-offs, washers and screws, as necessary. Tighten screws carefully, but securely.
  • Step 7 Make sure motherboard is not touching metal anywhere.
  • Step 8 Make sure slots and connectors fit into openings on back of case.
  • Step 9 Connect motherboard to power supply.
  • Step 10 Connect CPU fan, if you have one, to power supply.
  • Step 11 Connect reset and power switches to power supply.
  • Step 12 Connect LED indicators to power supply.
  • Step 13 Connect case speaker to motherboard.
  • Step 14 Check all connections.
  • Step 15 Test motherboard (and configure in CMOS if necessary) before installing other components of computer system.
  • TIPS AND WARNINGS
    • If possible, do installation in an uncarpeted area.
    • Be careful not to touch any chips. Handle board by its edges. Static damage (and even oil damage) may cause a failure months after the incident.
    • If you do not understand these instructions or you lack good manual dexterity, have a qualified technician install the motherboard for you
  • Mar 20, 2010 | Intel D946GZIS Motherboard
    My pc processor not hit when on the mother board my mother board is aopen mother board plaese give me salution
    If you mean that your processor pins does not fit in your motherboard, then they are not compatible. The processor pins must be exactly fit the motherboard.
    Besides, the processor type must be supported by the motherboard (If the motherboard is supporting P4, Core Dou, Quad, Celeron, Athlon, etc). You have to install the right processor for a particular motherboard. You have to know what particular
    processor is supported by your motherboard.. In your
    case, I believe it supports Pentium 4, but I cannot
    give you the exact speed in Ghz, as well as the clock speed. You can ask the dealer about it.
    Nov 22, 2009 | AOpen (MX4SGI4DN2PRE) Motherboard
    Where do i plug the power and reset and power led and hdd led in on the mother board?
    there isnt always a specific place for them just find a port that it will fit into i believe the ones that fit it are on the bottom right edge of the board if you have the case standing up and looking from the side
    Oct 09, 2009 | Asrock GE PRO-M2 Motherboard
    ASUS P5S800-VM mother board V Asus EN9500GT graphic card
    you would need a new mother board or change the graphics card
    Feb 11, 2009 | ASUS P5S800-VM Motherboard
    I have 20 asus 845 chipset p4b mother board after one year all the mother board going dead they have no respone what is the problem board has no physical damage
    You could be touching that and shocking them with ESD (Electro Static Discharge) This time of the year is bad for it and many people do it. I have never once have heard of 20 of the same Mainboards failing and ASUS at that. Try touching the metal of the case itself before your press the power button. This will keep you grounded.
    Jan 16, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
    FITTING MOTHERBOARD
    If you have not removed the old motherboard from the case, then you can identify the various front panel connectors as you disconnect them and label them. Some front panel connectors have labels printed on the connectors which makes it easy for you to identify its purpose. If you have already removed the old motherboard then you will need to trace each of the leads to the front panel to see what they are connected to (eg. the LEDs and switches etc).
    You will also need to identify on the new motherboard the various connectors for each function, eg power LED, hard drive LED, reset switch, power on switch, internal speaker etc. If you are lucky It may be printed on the motherboard, if not you will need to refer to the manual.
    NOTE the LEDs are polarity sensitive, if the LED does not light, then swap the connector around the other way.
    Nov 16, 2008 | Packard Bell Computers & Internet
    Biostar M4M70-M4 mounting question
    Of course it could make a difference. Any contact between an active voltage on a motherboard and the metal of the case will fry the motherboard and possibly the P/S. There are different sizes of standoffs to fit different cases and motherboards. Sometimes if a person doesn't use a sufficient number of standoffs, one corner or another of the motherboard can be inadvertently bent toward the case ground causing a short. Even the raised mounds you speak of need standoffs of some type if the surface of the raised mound encrouches upon a surface of the motherboard that has voltage on it.
    Feb 27, 2008 | Computers & Internet
    Computers & Internet Logo
    478 people viewed this question
    Alun Cox
    David Payne
    David Payne
