Question about Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FGS379ECC I turned on the broiler to low and I could here the gas running and when I opened the door the gas then lit up it came about two feet out into the room. After the oven cooled down then we opened the door and turned it on again and you could see the glow plug turn red but the gas was running and did not light. Adalin
  • 833 Answers
Adalin, this is a dangerous condition which requires diagnosis and replacement of safety components. I suggest you get a service person in.
Posted on Dec 13, 2007
My Magic Chef model 9112XUB wall oven will not light. It has power and gas but will not ignite.What can I do to fix it myself?
If this model has electronic ignition, you can open up the broiler door , turn on the oven, and look to the rear of the broiler...there should be a sort of glow plug getting reddish/orange. If not, the oven won't light and you will need to obtain an ignitor for the oven. these are available through appliance parts distributors such as Bell Parts Suppy. If it is a standing pilot model, then first check to see if the pilot is lit...if it's not lit try lighting...if it won't stay lit, then the thermocouple is probably bad and will need to be replaced
Dec 19, 2010 | Magic Chef 31100 Gas Kitchen Range
How to relight the pilot light?
There is an easy way to relight a pilot light in an oven/broiler if you do not have long fireplace matches and you are scared to stick your arm in with a regular lighter: Light a long stick of incense, but do not blow out the flame. Open the broiler door. Turn the oven to "broil" and extend the lit incense stick in \to the back of the broiler space. Wave the incense stick slowly back and forth below the broiler coil towards the rear of the oven until you hear the pilot light ignite, then pull the incense stick out, blow out the flame and insert into an incense holder.
Sep 19, 2010 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
I self-cleaned our oven yesterday. After waiting
in order to get the door open you can remove the door locking motor and turn the locking shaft.
there could be a problem with the excessive heat from the oven during the cleaning cycle check with frigidaire and see if there is any kind of recall for this problem
Apr 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gas range broiler element does not light.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 22, 2009 | Kitchen Ranges
FGF374 - Broiler and Bake does not stay on
The flame sensor has to prove the flame to stay lit. When it fails, the valve closes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
GE Electric Stove Broiler doesn't stay on
If the door is closed the broil element will cycle off an on normally. It should stay on most of the time if the door is in the broil position (partially open). If your range has an electronic control it will probably also have a hi and low broil setting. On low broil it will cycle off an on even with the door open but more with the door closed
Dec 31, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven turns on and off intermittently
I think your problem either lies in the thermostat or the gas valve. If you have one (Meter) take a reading at the coil side of the gas valve while starting and see if the signal drops out. If it does your thermostat is faulty. If it does'nt the coil on your gas valve is weak and dropping out as it heats up I have seen this quite frequently. You will have to read the schematic on your panel to see if it is registered in voltage dc or M/V.
Jun 11, 2008 | Ovens
Broiler glow bar stays on
the glow bar stays on in gas ranges the whole time the cycle is running if it didn't the safety valve couldn't open its normal
Jan 20, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
You most likely just have a weak ignitor. What you describe are classic symptoms, except I have never tried turning gas off.
If you have an amp clamp, check the amp draw of the ignitor. Clamp it on with the oven off. Turn the oven on and watch the amp draw. It will start climbing as it heats up and open the valve at about 3.2 amps. If you get 3.2 amps and it still doesn't light, you probably have a valve problem. I expect you will see it get up to 2.8- 3.0 then linger there for a while. This causes slow and erratic operation of the gas valve.
Even if you find this not to be the problem, this is the very first step to diagnosing a gas oven. You have to know the amp draw of the ignitor before you can go any further.
Post back to let me know what you find.
Oct 23, 2007 | Frigidaire FGB24T3A Gas Single Oven
Hotpoint RGB745 Burner Problems- Unique, needs help
Not sure, but sounds like you may have a gas pressure problem or the stove is set-up for the wrong type of gas.
Apr 25, 2007 | Hotpoint RGB745 Gas Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
52 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
