Ricoh Aficio 1515MF All-In-One Laser Printer
Problem for Ricoh Aficio 1515MF All-In-One Laser Printer
Hto rest lost passwords in nrg mp 2000 printers
By andruaceakha on Sep 19, 2009
Solution #1
posted on Sep 19, 2009
Somewhat Helpful)
cordwainer60
Rank: Guide
Rating: 83%, 6 votes
I have not been able to find any information on resetting the MP 2000s to eliminate the administrator password. However, have you tried logging into the printer via web access and using the default administrator name/password? Type the printer's IP address into your browser's address bar, and when the Web Access page appears, click Configuration leave the User Name blank and enter password for the password
If you gain access, you should be able to chance any other settings via that interface
If passwords are interfering with being able to use the basic machine functions, you may be able to use the control panel on the printer itself to access the Administrator Tools, and turn off the authentication requirements for those functions.
Last, if nothing else works, and there is any phone number or contact info on the printer anywhere...though I hate to subject you to being on hold for hours...try calling it.
I'm probably not thinking of something simple - like a handy reset button on the machine somewhere - but if anything else comes to light, I'll update this.
Comments:
Sep 19, 2009
- Aha! Here's a service procedure that is supposed to clear memory and set the printer back to the default password. PLEASE NOTE: This is normally done by a service technician, not the customer, and there is no end to the things you can screw up while in SP Mode.
You might want to download the entire service manual, available for free at http://fileshare.eshop.bg/ in case I've left anything out. (see Pages 5-1: Starting SP Mode, and 5-35: Memory Clear (NCS)) I've copied the most relevant sections below the outline instructions.
Good luck, we're all counting on you.
1) (IMPORTANT) Print a configuration sheet at the beginning. You will need the configuration sheet to restore the network settings.
2) Enter SP mode.
3) Enter SP 5-801-011 (Memory Clear > NCS).
4) Press [Execute].
5) You will be asked for confirmation. (IMPORTANT) This will reset all of the network and interface settings. Make sure you have printed the configuration sheet. Press [Execute] once again.
6) Turn off the device, then turn it back on.
7) Restore all the network settings to the values of the configuration sheet.
8) The above steps should have reset the password to the factory default, "password".
9) Finally, log in to the device and change the password to your own. This can be done using Web Image Monitor or telnet ("passwd" command).
Sep 19, 2009
That should be the rest of the info you need,
cordwainer
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 1515MF All-In-One
Questions and Unsolved Problems for Ricoh Aficio 1515MF All-In-One
Do you recommend Ricoh Aficio 1515MF All-In-One Laser Printer?
Answer
Answer
we just got a used ricoh aficio 1515 in our office. We can't figure out how to set up the scanner to... (More)
Answer
what ricoh printer is compatable to the ricoh africio 1515
Answer
It just says replace photoconductor but I don't know who to call because we bought this second hand
Answer
Hooked it up at a new location, installed driver. When you try to print something, multiple pages of... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Aficio 1515MF All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
