Refrigerators Logo
Posted on Sep 19, 2009
Same thing when i open the fridge the lights keep flickering over n over and my temp stat thing say for both freezer n fridge -44 degrees... mind u my ice has melted and my food is going rotten :/
Ziggy Lazer
Level 1:
  • Contributor 28 Answers
  • Posted on Sep 19, 2009
Ziggy Lazer
Contributor
Level 1:
Answers
28
Questions
0
Helped
6704
Points
72
The flickering lights may be caused by a bad bulb
and/or socket, perhaps the bulb needs to be tightened.
get a different fridge!
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Beko fridge freezer. The interior light still comes on but both the fridge and freezer compartments aren't getting as cold as should (probably about only 20%)
hi there. well if its a standard fridge it could be 1- the stat 2-lack of refrigerant 3-or motor.difficult to check without a visual but if your condenser is nice and warm and the motor is not overheating then it could be the stat.either change it or turn off fridge bypass the stat wire and try.it will over freeze.(keep safety in mind first) if frost free then again condenser warm ,compressor not overhated then likely to b your defrost timer.(normally hiden near compressor at rear/good luck Ali
Have temp gage almost to 9 (per instructions to make warmer ) but still at 33 degrees F. need to make warmer
the freezer cools the fridge side so if you open the air flow up going in to the fridge it will only get colder. so cut the air flow down low and it should warm up. this causes the freezer to get cold quicker too because there is more cold air available in the freezer so it cuts off the compressor sooner.
think about how it works. if you doing everything right then you need to listen to be sure the stat is cycling the compressor or does it never get cut off by the stat.
Compressor overheated and shut down.
Pleas put setting in the middle and give it 24 hrs and check temps
freezer would be good at 0 to 10 f
I thing you have the damper door closed.
1helpful
I recently had to throw away some questionable food that had partially thawed in the freezer cabinet of my kenmoore, model# 253.67882508 fridge with freezer on top. i keep this fridge in my garage and in...
probably,there is a garage kit available that willallow it to work at colder temps,listed in owners manule under accessories the thermostat senses refrig compartment temps.soif garage temp is below 40 or so the thermostat just doen't turn the unit on enough or not at all
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Ice build up in freezer and temp in fridge section not very cold
just needs to be defrosted ice is blocking the vent for the bottom defrost it and should be good
1helpful
Refrigerator cools, but not cool enough, even with temp adjustment turned to coldest setting. Freezer only gets down to 0. Fridge at 44 degrees
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
7helpful
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
