Question about Aluratek AUS0204
Hp 3390 memory is off
The desktop of my hp 3390 laserjet is off, the lights are off and the system is down, how can i put the software again.
is there some utility to install the firmware again ?
my mail is mambo0721@hotmail.com
  • 51 Answers
Please reinstall the hp cd in your pc once again then go to settings/printer and faxes/click on that add a new printer ..thats all
thank you...
Posted on Jan 05, 2008
Code 10. 1000 supply error hp laserjet 3390
Remove the toner and shake it a little. You can put the toner back in the printer. If this does not fix the issue, Turn off the printer, unplug the power cable from wall outlet. Wait for 1 hour and plug the power cable and power on the printer
Regards,
Sean
Apr 11, 2013 | HP LaserJet 3390 All-In-One Printer
3390 cutting off page with internet explorer
If this is a large print job your printer requires more memory to process. I assume it is cutting off about a third of the image.
Apr 05, 2012 | HP LaserJet 3390 Printer
Hp 3390 work with w7 64x in scan mode ???
Your 3390 will only scan by using the Windows scanning software, the HP solutions do not work on Windows 7.
This is how you can scan from your 3390, assuming you have been able to get it working for printing on your system.
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scan .
  4. Click New Scan , and then click Scan .
Feb 26, 2011 | HP LaserJet M2727 MFP Series PS
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
Where do i install memory on an hp laserjet 3390
There are many ways on how to install memory for printers. Many of these printers are like puzzles trying to find how to open them. I tried looking for help from HP and found nothing. I posted a link below that helps you through installing memory in another model printer. I hope it helps!
http://www.hpprintermemory.com/installing_flash_simm.html
Goodluck! :)
Jan 15, 2011 | HP LaserJet 3390 All-In-One Printer
When printing from an HP Laserjet 3390 all in one printer, getting a thick black line down one side of the paper.
if it is uniform, replace the cartridge
if it is not uniform, you have to replace the fuser asembly
Mar 16, 2010 | HP LaserJet 3390 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
Feb 12, 2009 | HP LaserJet 3390 All-in-One Multifunction...
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
Aluratek AUS0204 Logo
99 people viewed this question
Top Aluratek Computers & Internet Experts
Don Hart
Marcin
Are you an Aluratek Computer and Internet Expert? Answer questions, earn points and help others
