Question about Sony Handycam DCR-DVD108 DVD Camcorder
Sony handycam battery is not charging
There is some problem with battery charging and the recording button.As soon as i press the recording burron the mode changes and there is continues click sound inside the handycam.I changed the battery but still some problem is there? please help
  • 326 Answers
SOURCE: multi-coloured vertical lines on LCD screen and view finder
Hello, there is a chance for the Sony recall. Please contact your nearest Authorized Sony Service. If you need more info please advice.
Posted on Mar 21, 2007
  • 169 Answers
SOURCE: black lcd screeen on my sony handycam
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....go to a sony service center for replacing that...i know it is free for replacing that sensor cause that is the recall product not only on sony but in other brand because the manufacturer of their sensor is only one company....
Posted on Oct 24, 2007
  • 377 Answers
SOURCE: Finalize cd-rw on Sony HandyCam DCR-DVD92
hi dear
you can finalize your dcr in record position
going to disc manager find the finalize
and finish
Posted on Apr 07, 2008
  • 10594 Answers
SOURCE: Can not set the camcorder to Super Nightshot Plus mode
To enable " Super Night Shot " option, find slide switch at top of camera as shown in picture...Regards,
Posted on Aug 21, 2008
SOURCE: Sony Handycam DCR-DVD108 - Carl Zeiss Vario-Tessar Optical Zoom 40x
Please, I need support of camera technical carl zeiss vario tessar with otptical zoom 40x
Posted on Oct 09, 2008
  • 320 Answers
SOURCE: sony handycam "carl zeiss lens 40xoptical zoom
A common problem in the Sony camcorders is a stuck iris assy, the part of the lens assembly that regulates the light coming into the camera. It sounds like that is the problem with your camcorder. It can be verified by zooming your lens out and it and shining a light into the lens to see it you can actually see the CCD at the back of the lens. It helps if you know what you're looking for, but if all you see is black, then the iris is stuck closed and you will need a qualified tech to look at the unit. Please, if this information has answered your question, I would appreciate a good rating. Thanks!
Posted on Oct 23, 2008
0 characters
1 Points
Set time and date of Handycam
its a ruttin problem you just change the LCD FLAP its easily available ,just change it and find the magic,
Aug 30, 2009 | Sony DCR-HC32E DV Digital Camcorder
Handycam CCD TR517 Doesn't record
These models have a switch for 3 different modes of record. one where you press the red button once, one for having to hold the red button in and a 5 second record feature, check this mode. also check and make sure the tape you are using did not have the record save switch slid into record save position..
Jul 20, 2009 | Sony Handycam CCD-TR517 Camcorder
Battery symbol blinking when put on charging.
It does sound like the battery needs to be replaced, but it also could be an internal charging problem with the camcorder. I would try a new battery first, since it's the easiest and cheapest option
Oct 19, 2008 | Sony Handycam DCR-TRV38 Mini DV Digital...
There is a built-in rechargeable battery in the camera and after approx 3 months it will be completely discharged if the camcorder is not used. To recharge: Connect camcorder to wall outlet using the supplied AC Adapter with the power switch turned OFF for more than 24 hours. (To keep the internal batter charged, try to plug the camera in every couple of months or attach a fully charged external battery for at least 24hrs). To set the clock: Set the power switch to CAMERA and then press MENU. Turn the dial to select CLOCK SET, scroll to the toolbox looking icon -it may say DEMO MODE next to it. Then press the dial. Turn the dial to select the desired year, month, day and then pressing the dial to set each as you go. For the tape speed go to Menu settings scroll to find Tape settings (TAPE SET), select REC MODE and from there you can change the tape speed from SP to LP. Hope this helps. I have the Sony Digital 8 Handycam DCR-TRV250 I purchased about 3 or 4 years ago (700x digital zoom etc).
May 21, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
Computer mode
hi follow this steps: Make sure that you have installed the USB driver for the handycam. You can download the drivers from this link: Sony Asia Pacific Support Website--Download Page for HC40E USB Driver for Windows. Connect the handycam to the AC adaptor (the same as putting it on charge). Set the handycam to USB stream mode. (Press P-menu, press MENU, Press EDIT/PLAY, Press USB MODE, Press USB Stream.) Set the tape at the point from where you want to start capturing in PC. Connect the handycam and the PC with the USB cable. (USB-Mode appears on the handycam LCD / viewfinder.) Start Windows Movie Maker. Click on the 'Capture..' link to start the wizard. Select the Sony Digital Imaging Device. Click Next. Specify the file name and path for the capture video. Click Next. Select the desired capture format and Click Next. (Leave it to recommended setting if you are not sure.) The dialog box now displays the Start Capture and End Capture buttons on the left and preview window on the right. Play the tape on the handycam. The video from handycam should appear in the preview window of WMM. Click the Start Capture button to start capturing the video. Click End Capture to pause or stop recording. Click the Finish button. The .wmv file will be saved in the path specified in step 7.
Oct 02, 2007 | Sony Handycam DCR-TRV265E Digital...
Sony Handycam PC101E Record button/power switch...
there are loose connection of the power switch try to clean the contact of the switch and adjust it...use a pencil eraser only do not use any spray and liquid.....if you cannot put it back don not try open the camera....better go to the qualified and service center....
Aug 10, 2007 | Sony Handycam DCR-PC101E Mini DV Digital...
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
155 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
