Back to:
Tags:
Intel Pentium 4, 3 GHz Processor
Computer Shuts down
posted by ashir on Dec 13, 2007
Hello Sir,
nowadays i m exprensing a problem that my computer shuts down when i use it for more then 10 min..
I have done no hardware changes and this till yesterday the shutdown time was 30 min but now it has gone to 10 minutes.
please help
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 13, 2007
Not Rated (0)
TabishDon
Rank:Wiz Wiz
Rating: 92%, 13 votes
Well your processor may be damaged..
dont worry may be it is not damaged so what do you do is that open the cover of your computer.... Then start it and keep the cover opened making sure that you can see the processor fan running...
See that if the processor fan is running...
then with the help of a torch see that may be the fan is being restricted or it is moving slowly.
this slowness of the fan heats up the processor and makes it shut down you PC
if the is running slowly take out the fan using the user guide of the processor and then lubricate it with motor oil.
it IT Does not work then there is a problem with your processor so please check by placeing another supportive processor and check it!
Rating Locked! (?) ashir has rated this solution as Not Rated
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Computer Shuts down:
I don't want to Accept this solution
Can you Help with these Processors problems?
Processors
hi i keep having a dialogue box appear on my laptop when i...
Processors
no trabaja y cuando llamo a att me disen que el sofware...
Intel (RK80532PG0881M) Pentium 4, 3 GHz...
My e-mail page has been changed since yesterday. I have...
How do I reset the password for the parental controls on...
1.3 amd processor and ecs mobo
Loading problems.
Repair Service
Find Processor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
