Question about Lexmark E234 Laser Printer
Second light down , yellow light is on - Lexmark E234 Laser Printer
  • 25 Answers
That means you need to replace the toner cartridge it almost empty.
http://www.lexmark.com/publications/pdfs/e234/eng/ug.pdf
Posted on Jan 22, 2008
Turns on with snow and yellow light under lamp. Why does it shut down after 20 seconds?
yellow steady light is overheating. you have a stuck fan or its all clogged with dust. The only way to fix it is to find what is causing it to overheat or prevent the fan from spinning. It is not lamp related unless you bought a lamp that does not have an Osram bulb inside.
Sep 08, 2015 | Mitsubishi WD-65734 65" HDTV
My tablet cannot connect to internet and Netflix and Amazon are not working either. there is a yellow light on center button; do not know what button is for. Is yellow light showing router is broken
Not knowing what kind of tablet you have, I'll give you the general troubleshooting steps:
1) Turn off your tablet. Power it all the way down.
2) Unplug your router.
3) Wait 10 seconds.
4) Plug your router back in.
5) Wait 60 seconds.
6) Turn your tablet back on.
Aug 30, 2015 | Linksys WRT110 Wireless Router
The power light is constantly blinking in yellow. before this happened the yellow light was on without blinking I turned it off, once I turned it back on the light turned green but the screen...
try unplugging your t.v for 10-20 seconds. plug it back in. if your power light continues to flash your t.v is the issue. you should be able to google your issue or check your owners manual about the problem. unplugging the t.v is the last ditch effort. Good Luck!
May 18, 2011 | Akai LCT2715 27 in. LCD Television
Yellow engine light
Yellow engine light on the dash board of Toyota Camry is the indication of low oil in car.----------- Get the oil checked and refilled.Driving the car with low oil is not advisable.------------- There is a reset procedure to stop this yellow light on dash.In some cases this helps ,but in some cases the oil needs to be refilled to stop this yellow light.------------- I will mention the reset procedure as follows:-- Turn on the ignition switch, set the mileometer reading to miles not trip meter, turn off the ignition fully, press the button to reset the trip meter and keep it pressed down as you turn on the ignition key to key on engine off, keep it pressed down for about 15 seconds and then the light will be reset. -------------- Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 09, 2010 | 2000 Toyota Camry
It wont turn on just flashed red light and wont give the disk back
watch the lights on the front when you try to turn it on. If the blue light flashes yellow for a second, you have ahardware failure, so-called Yellow Light of Death. You can get the disc out by turning off the switch at the back, then hold down the eject button and turn the back button on again.
May 01, 2010 | Sony Playstation 3 (PS3) Console
Wen i power switch my PS3 red light comes on then wen i pressed down once to get in on beeps once, then green light comes on for a second then yellow light to a steady BLINKING RED LIGHT!!! And does NOT...
This is called the yellow light of death. Cause is sever heat damage to the internal components. Either send it in for repair or replace. Sorry about this but the truth is brutal.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Frozen. Yellow light on, Buttons appear to do nothing.
Holding down the Enter key on the keypad for 30 seconds forces the scanner to reset. It is called a forced power down.
May 26, 2009 | Symbol P470-SR1211100FB Handheld
I use nissan sentra 2002 my service engine soon is on for 2weeks
Finding out what the code number is, is the first step.
You can find this easily by watching the blinking yellow check engine light and counting the number of flashes for each of the numbers in the 4 digit fault code.
To do this without a code reader; sit in the car and turn the ignition on (do not start the car) and after 3 seconds push the accelerator pedal all the way down to the floor and release fully (pull your floor mat out from under the gas pedal). After the 3 seconds, do this 5 times quickly, in less than 5 seconds. Then hold the accelerator pedal down for exactly 7 seconds and release it fully. Then within 10 seconds, the yellow check engine light will begin to blink.
The numbers of blinks will go from 1 to 10. A 10 will represent a "0".
For example; 0303 would be 1st number is 10 flashes, short pause then 3 flashes, short pause then 10 flashes, short pause and 3 flashes. It will repeat this again if there is only one fault code. There could be other fault codes and you would count those in the same way.
The 0303 code means that you have a cylinder misfire in the #3 cylinder. This could be a fouled plug, poor connection between the plug and the coil or something else.
To erase the code hold the gas pedal down while the yellow light is blinking for about 15 seconds then turn off the ingnition. Code will now be reset and light will go out.
If for some reason you do not get the yellow light to start blinking, tturn off the ignition and try it again. You may wish to get a watch with a second hand as the time is critical as to the seconds between steps.
After you find out what codes you have, send back an email and we can document the actual codes and the problems you are having.
Bob - 2003 Nissan Sentra SE-R spec V
Feb 11, 2009 | 2003 Nissan Sentra
Lexmark E234 Laser Printer Logo
193 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
