Question about Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Color problem I just moved to a new home and after the cable guy came to hook up th cable, the screen has green spots in the upper left corner and lower right corner. What could have caused this and how can I fix it? We had digital cable before through comcast and never had this problem. This digital box is from Time Warner Cable. The picture is messed up even playing a DVD and not just the cable.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,001 Answers
Lightning Cable , USB Charger Cable for Apple, Lightning Cable for Apple,Cable Cords Connector with Nylon Braided https://www.amazon.com/Charm-2Pack-4-9Feet-1-5Meters-Lightning-Connector/dp/B01DU8UQF2/ref=sr_1_10?ie=UTF8&qid=1483520960&sr=8-10&keywords=Charm%2Bsonic&th=1
Posted on Jan 04, 2017
Color line all over tv as splashed after lightning cracked den window and hit tv!
Posted on Oct 13, 2008
    Problem Solver:
  • 6 Answers
Is there a speaker ( other than built in ) near the tv? ( if so, move speaker away from tv.
Posted on Dec 15, 2007
Cannot get sound. green cable is not connected. three cables connected together-- red and blue cables connected to aux in left and right. do not see where green cable should be connected. we just...
The actual color the head on a given cable is irrelevant as long as it connects an output to its compatible input.
Jacks on the electronics follow a common color code and are labeled for the color-blind.
Analog audio jacks are usually red (right) and white (left).
Composite video is usually yellow.
Red, green and blue are traditionally for Component Video. In other words, NOT SOUND.
A disconnected cable is usually a good reason for a signal to fail. But one should not guess where they go.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-TH-C50J-Home-Theater-Systems-manual/id/318ci575/t/2/
Get the basics set up first.
Mar 27, 2011 | JVC TH-C50 System
Problem with JVC CRT TV (slim) with screen to have red color at the lower left (facing the TV) corner and a green color on the upper right corner of the screen. Sometimes while watching TV shows, the upper...
There is strong magnetic field around the TV. This may be due to the tower speakers or any portable radio kept close by.
Re orient the TV try switching OFF / ON at the intervals of 30 minutes. The built in auto de-gauser will correct the problem. In cable TV program if the picture is OK, nothing wrong in the TV.
Check with a different CD.
May 19, 2010 | JVC AV-21QMG3 21" TV
OUR HITACHI 50V500A HAS COLOR PROBLEMS WE MOVED IT
This is an LCD rear screen projection TV. There is a Red, Green and Blue LCD pallet that is mounted on what they call an X-cube. If all you are getting is Red and green then something happened to the blue pallet. Either the Ribbon connector came off or is loose or something worse. How hard did you mover it?
Another thought. How is it hooked up. If component then this may be the issue as component video connections are Red, Green and Blue. Just a thought.
Let me know.
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
Zenith 60
why is there no answer for this question?
May 29, 2009 | Zenith P60W38 60 in. Plasma HDTV
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Jun 04, 2008 | Zenith A36B41W 36" TV
My picture was distorted by a speaker magnet
well , yes , you have to purchase a DEGAUSSING COIL to take care of this problem and know how to use it (which its very easy) available at electronic stores (try EBAY) What you do is you place the DEGAUSSING COIL in front of the color spot and do circular motions while slowly stepping away from it . that should take care of that.
Apr 12, 2008 | Panasonic CT-34WX54 34" TV
TH-50PX60U picture problem
Try to replace the Logic Scan board on the upper left side of your tv. The part no. is printed on the board and you can order it from Panasonic's Website. Also check the Service Manual for the part description and part no.
Oct 17, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Sharp 27DV-S100 27 in. TV/VCR/DVD Combo Logo
139 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
